KCNC Steady Pedals
KCNC Steady Pedals Black$155.00  1 Remaining
KCNC Steady Pedals Gold$155.00  2 Remaining
KCNC Steady Pedals Red$155.00  1 Remaining
The "Steady" is KCNC's wide platform pedal, suitable for use in BMX and cross country.
Replaceable semi sharp steel pins help provide grip and inspire confidence. Internally, a needle bearing and standard sealed cartridge bearing share the work of keeping the pedal spinning smooth. Additional seals are installed on either end of the pedal body to keep the dirt and moisture out. The 7075 aluminum pedal body is attractively machined and finished in gold or black anodizing. The stainless steel spindle is given special TiN (titanium nitride) coating to improve wear life against the pedal's needle bearing. This treatment gives the steel surface a durable gold sheen.
Includes a tool for installation and removal of steel pins.
Weight: 335g / pair
Comment on KCNC Steady Pedals
