KCNC Shock Pump
KCNC Shock Pump
KCNC Shock Pump
KCNC Shock Pump
KCNC Shock Pump
KCNC Shock Pump
Sign Up For Our Newsletter
You're Signed Up!
CompatibilityAll major shock designs
KCNC Shock Pump Shock Pump $51.00 Notify Me When Available
Details
KCNC's expertly machined shock pump shows an obvious level of skill, as well as an intense amount of design prowess. Built to withstand heavy abuse, while remaining aesthetically pleasing, the KCNC shock pump is perfect for any professional shop, or even the home mechanic that won't settle for second best. Covered with intricate machining details and tool paths to add character to the pump, there is no doubt that this is the most visually complex shock pump we've ever seen.
Compatibilty
The KCNC shock pump will work with all current major fork and rear shock designs.
Comment on KCNC Shock Pump
