KCNC SC11 MTB Seatpost Collar
KCNC SC11 MTB Seatpost Collar 31.8, Black$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 31.8, Blue$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 31.8, Gold$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 31.8, Green$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 31.8, Red$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 31.8, Silver$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 34.9, Black$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 34.9, Blue$24.00 Notify Me When Available
KCNC SC11 MTB Seatpost Collar 34.9, Gold$24.00 Notify Me When Available
KCNC SC11 MTB Seatpost Collar 34.9, Green$24.00 Notify Me When Available
KCNC SC11 MTB Seatpost Collar 34.9, Red$24.00  1 Remaining
KCNC SC11 MTB Seatpost Collar 34.9, Silver$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 36.4, Black$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 38.2, Black$24.00 In Stock
KCNC SC11 MTB Seatpost Collar 39.0, Black$24.00 In Stock
Weight, 31.8 mm10.5 grams
Weight, 34.9 mm11.5 grams
Weight, 36.4 mm13.0 grams
Weight, 38.2 mm13.5 grams
Weight, 39.0 mm12.5 grams
Collar Material7075 aluminum
Bolt Materialscandium
KCNC's SC11 seatpost collar is designed to hold up to the abuse of off road riding while maintaining an exceptionally low weight. This low weight is achieved through aggressive machine work which includes the SC11's unique scalloped clamp band. This collar is equipped with a lightweight M7 scandium bolt. The bolt has a full length 4 mm hex key slot to spread the tightening load over a wider area, reducing the possibility of breakage.
When installing an SC11 seatpost collar, use of a torque wrench is highly recommended. When tightening the clamp bolt, fully insert a 4 mm hex key and torque to 8 Nm.
