KCNC SC Pro Lite Seatpost
KCNC SC Pro Lite Seatpost 27.2mm Length: 350mm$100.00 Notify Me When Available
KCNC SC Pro Lite Seatpost 27.2mm Length: 400mm$115.00 Notify Me When Available
KCNC SC Pro Lite Seatpost 30.9mm Length: 350mm$110.00 In Stock
KCNC SC Pro Lite Seatpost 30.9mm Length: 400mm$125.00  2 Remaining
KCNC SC Pro Lite Seatpost 31.6mm Length: 350mm$120.00 In Stock
KCNC SC Pro Lite Seatpost 31.6mm Length: 400mm$135.00 In Stock
Weight, 27.2 x 350175 grams
Weight, 27.2 x 400188 grams
Weight, 30.9 x 350206 grams
Weight, 30.9 x 400214 grams
Weight, 31.6 x 350203 grams
Weight, 31.6 x 400219 grams
Materialscandium T-7451
Available Diameters27.2, 30.9, 31.6 mm
Available Lengths350, 400 mm
Useroad, cross country
Rider Weight Limit100 kg (220 lbs)
KCNC's SC Pro Lite seatpost is one of our most popular items here at Fair Wheel. This lightweight, fully machined Scandium seatpost has an 18 mm offset and uses a simple design in securing your saddle rails. In an effort to keep weight as low as possible the SC Pro Lite post utilizes Scandium and titanium hardware.
The SC Pro Lite features independent saddle tilt and fore/aft adjustments. Both 4 mm and 5mm hex wrenches are required, and use of a torque wrench is recommended.
