KCNC Removable Core Valve Extender
Sign Up For Our Newsletter
You're Signed Up!
Weight6.7 grams, pair
Lenght52mm
Valve CompatibilityPresta - Removable Core Tubes / Tubulars
KCNC Removable Core Valve Extender 52mm, Black $12.00 In Stock
KCNC Removable Core Valve Extender 52mm, Red $12.00 In Stock
Details
KCNC's lightweight valve extenders are perfect for setting up your deep section carbon rims. Depending on what innertube or tubular tire you're using you might find that you need a valve extender with a removable core. Vittoria tubulars and innertubes and Vredestein products like their Latex Tube and Tri Comp Tubular require removable core valve extenders.
Instillation
Before installing KCNC valve extenders, remove the valve core from your tube. The KCNC extenders come with their own. Keep the spare in your saddlebag just in case. We also recommend wrapping Teflon tape on the threads of both the inner tube and the valve core for increased life and a greater seal.
