Kcnc Rear 12mm Indexing Thru Axles
$30.00
Known for their extensive repertoire of aftermarket components designed to aesthetically accent, and mechanically perfect any level of build, KCNC is a name real world cyclists trust.
With the introduction of their 12x142mm thru axle skewers, KCNC looks to set themselves apart with a unique style and mechanical advantage over other aftermarket skewers. Equipped with an easy to use system for dialing in the perfect skewer angle for your particular frame, simply press the red button in the center of the skewer handle and rotate the cam into any desired position is seconds. Additionally, each KCNC 12x142mm thru axle skewer utilizes a free-floating knurled endcap, coupled with a brass washer in order to minimize friction between the skewer and frame, ensuring a proper fit every time. Available in a plethora of vibrant colors, ideal for tuning the aesthetic of your current ride or next build, the 12x142mm thru axle skewers from KCNC are a simple way of adding a dash of flair.
Cam Material6061 aluminum
Rod Material7075 T6 aluminum
Axle Diameter12mm
Axle Length142mm
Weights
E-Thru66 grams
Maxle64 grams
Syntace X-1265 grams
