Kcnc Razor Disc Rotor
$25.00
Razor rotors push the limits of what a stainless steel rotor can be. By utilizing such a common and reliable material, KCNC has created an inexpensive and durable disc brake rotor that is also very lightweight. This minimalistic yet stylish design safely uses as little material as possible to achieve weights that are normally reserved for rotors manufactured from more exotic materials.
KCNC doesn't cut corners in the manufacturing process. Each rotor is precision machined with double ground, perfectly parallel braking surfaces. Subtle laser cut logos adorn the rotors' arms.
Six steel mounting bolts are included with each rotor. These bolts are coated with a thread locking material for maximum security. When installing a Razor rotor, you will need a T25 torx wrench. We also recommend using a torque wrench, tightening each bolt to 6 Nm.
Weight, 140 mm 62 grams
Weight, 160 mm 74 grams
Weight, 180 mm 95 grams
Material stainless steel
