KCNC Razor Disc Brake Rotor
KCNC Razor Disc Brake Rotor 140 mm$25.00 In Stock
KCNC Razor Disc Brake Rotor 160 mm$25.00 In Stock
KCNC Razor Disc Brake Rotor 180 mm$25.00 In Stock
Weight, 140 mm62 grams
Weight, 160 mm74 grams
Weight, 180 mm95 grams
Materialstainless steel
Razor rotors push the limits of what a stainless steel rotor can be. By utilizing such a common and reliable material, KCNC has created an inexpensive and durable disc brake rotor that is also very lightweight. This minimalistic yet stylish design safely uses as little material as possible to achieve weights that are normally reserved for rotors manufactured from more exotic materials.
KCNC doesn't cut corners in the manufacturing process. Each rotor is precision machined with double ground, perfectly parallel braking surfaces. Subtle laser cut logos adorn the rotors' arms.
Six steel mounting bolts are included with each rotor. These bolts are coated with a thread locking material for maximum security. When installing a Razor rotor, you will need a T25 torx wrench. We also recommend using a torque wrench, tightening each bolt to 6 Nm.
Comment on KCNC Razor Disc Brake Rotor
