KCNC Radiant R1 Headset
KCNC Radiant R1 Headset Black $120.00 In Stock
KCNC Radiant R1 Headset Blue $120.00 In Stock
KCNC Radiant R1 Headset Gold $120.00 In Stock
KCNC Radiant R1 Headset Green $120.00 In Stock
KCNC Radiant R1 Headset Red $120.00 In Stock
KCNC Radiant R1 Headset Silver $120.00 In Stock
Weight62 grams
Steerer Compatibility1-1/8" (1.125")
Bearingstainless steel cartridge, angular contact
Bearing OD41 mm x 45 deg
Stack Height6.5 mm
Headset CompatibilityCane Creek IS-2, IS-3 Compatible
KCNC's Radiant series headsets are an excellent option for upgrade over a frame's stock headset, or as a replacement for a worn headset. The R1 features high quality stainless steel cartridge bearings and CNC machined 6061 aluminum hardware, all within a low stack height, light weight package. Included with each headset is a matching top cap and bolt and 1-1/8" star nut.
The R1 headset's crown race is split for quick and easy installation. Included with each headset are three .2 mm shims for adjusting the clearance of the headset's upper bearing cover. With the exception of the included star nut, no specialty tools are required for installation of an R1 headset.
Comment on KCNC Radiant R1 Headset
