KCNC Radiant KR1 1.125-1.5 inch Tapered Headset
KCNC Radiant KR1 1.125-1.5 inch Tapered Headset Black $135.00 In Stock
KCNC Radiant KR1 1.125-1.5 inch Tapered Headset Blue $135.00 In Stock
KCNC Radiant KR1 1.125-1.5 inch Tapered Headset Gold $135.00 In Stock
KCNC Radiant KR1 1.125-1.5 inch Tapered Headset Green $135.00  1 Remaining
KCNC Radiant KR1 1.125-1.5 inch Tapered Headset Red $135.00 In Stock
KCNC Radiant KR1 1.125-1.5 inch Tapered Headset Silver $135.00 In Stock
Weight69 grams
Bearingsstainless steel cartridge, angular contact
SHIS FitIS41/28.6|IS52/40
Steerer Compatibilitytapered, 1-1/8 inch - 1-1/2" (1.125" - 1.5 inch)
Upper Bearing OD41 mm x 45 deg
Lower Bearing OD52 mm x 45 deg
KR1 Headset Details
KCNC's Radiant series headsets are an excellent option for upgrade over a frame's stock headset, or as a replacement for a worn headset. The KR1 tapered integrated headset features high quality stainless steel cartridge bearings and CNC machined 6061 aluminum hardware, all within a low stack height, light weight package. Included with each headset is a matching top cap and bolt and 1-1/8 inch star nut.
The KR1 headset's crown race is split for quick and easy installation. Included with each headset are three .2 mm shims for adjusting the clearance of the headset's upper bearing cover. With the exception of the included star nut, no specialty tools are required for installation of a KR1 headset.
Comment on KCNC Radiant KR1 1.125-1.5 inch Tapered Headset
