KCNC Mountain Chainrings
KCNC Mountain Chainrings 104 BCD - 32 tooth $70.00 Notify Me When Available
KCNC Mountain Chainrings 104 BCD - 42 tooth $78.00 Notify Me When Available
KCNC Mountain Chainrings 104 BCD - 44 tooth $78.00 Notify Me When Available
KCNC Mountain Chainrings 94 BCD - 29 tooth $70.00 In Stock
Weight - 22t/24t
18 grams
Weight - 32t/34t
34 grams
Weight - 44t
87 grams
Material
7075 aluminum
A great deal of design ingenuity goes into the production of chainrings. Steel pins and relieved ramps must be properly shaped and placed to allow the chain to shift smoothly from ring to ring without jamming or wearing too quickly through the delicate aluminum material. KCNC has accomplished this, and they've done a magnificent job with their line of chainrings in the process. While these aren't the lightest or most flashy rings around, they simply work well. This makes them a great inexpensive aftermarket replacement once your stock chainrings wear out, or as a first set for cranksets sold without chainrings. KCNC rings have a subtle bead-blasted and black anodized finished finish that looks great with most currently available cranksets. A tasteful amount of machining helps save weight and add some sparkle to non-wearing parts of the rings.
KCNC's line of mountain chainrings are compatible with 4-bolt 104/64 BCD cranksets. Installation requires tools for removing chainring bolts, and in some cases removal of the right side crank arm will be required.
Comment on KCNC Mountain Chainrings
