KCNC Majestic Seat Mast
KCNC Majestic Seat Mast 34.9, Black, 0 offset, 120mm length$130.00 Notify Me When Available
KCNC Majestic Seat Mast 34.9, Black, 0 offset, 75mm length$115.00 In Stock
KCNC Majestic Seat Mast 34.9, Black, 25 offset, 120mm Length$130.00 Notify Me When Available
KCNC Majestic Seat Mast 34.9, Black, 25 offset, 75mm Length$115.00 In Stock
KCNC Majestic Seat Mast 34.9, Gold, 0 offset, 75mm length$115.00 In Stock
KCNC Majestic Seat Mast 34.9, Red, 0 offset, 75mm length$115.00 In Stock
KCNC Majestic Seat Mast 34.9, Red, 25 offset, 75mm Length$115.00 In Stock
KCNC Majestic Seat Mast 34.9, Silver, 25 offset, 75mm Length$115.00 In Stock
Diameter34.9mm
Lengths:75mm, 120mm
Offset:0mm, 25mm
Colors:Black, Gold, Red, Silver
Weight:88-121 grams
Material7075
Kcnc Majestic integrated seat mast head is built from 7075 series alloy and includes titanium bolts. M6 for mounting the seat and M5 for mounting the mast.Offered in 4 colors and two offsets. The standard mast provides 2cm of height adjustment. Also available is an extended mast for those that need more seat height after the frame has been cut. The 120mm mast head provides up to an additional 5 cm of adjustment making for a total of 7 cm of adjustment.
75mm, 88 grams.
75mm, 25mm offset, 101 grams
120mm, 109 grmas.
120mm, 25mm offset, 121 grams
Installation/Assembly
5nm max torque for mounting to the frame.
5nm max torque for mounting the seat to the head.
Comment on KCNC Majestic Seat Mast
