KCNC
KCNC "Blade" Mountain Chainrings
Closeout - 50% Discount Specifications Weight, 22 tooth 17 grams Weight, 29 tooth 20 grams Weight, 32 tooth 33 grams Weight,...
$60.00  $30.00
Save: $30.00 off
11 options.View
KCNC "Blade" Road Chainrings
Closeout - 50% Discount Specifications Weight, 34 t - 110 BCD 30 grams Weight, 50 t - 110 BCD 85 grams Weight, 39 t - 130 BCD 39...
$60.00  $30.00
Save: $30.00 off
6 options.View
KCNC 'Outta My Face' MTB Bar End Plugs
KCNC 'Outta My Face' MTB Bar-end Plugs Colorful, secure fitting CNC machined 6061 aluminum bar-end plugs for your mountain bike, available in Black,...
$25.00
4 options.View
KCNC 10 Speed Cassette, Campagnolo
Specifications Weight, 11-21 120 grams Weight, 12-25 156 grams Weight, 12-26 160 grams Detail KCNC's machined cassettes use a combination of...
$275.00  $206.25
Save: $68.75 off
4 options.View
KCNC 10 Speed Cassette, Shimano
Specifications Weight, 11-23 113 grams Weight, 12-25 142 grams Weight, 12-27 148 grams Detail KCNC's machined cassettes use a combination of...
$275.00  $206.25
Save: $68.75 off
2 options.View
KCNC 10 Speed Titanium Cassette, Shimano
Specifications Material6/4 Titanium, 7075 Al. FitsShimano 10spd Range11-23, 12-25, 12-27 Weight 11-23107 grams Weight 12-25127 grams Weight 12-27127...
$390.00
3 options.View
KCNC 7075 Cantilever Brake Set
Specifications Weight, Complete Set250 grams Weight, Caliper Pair w/Pads80 grams Weight, Fork Housing Stop38 grams Weight, Seatpost Collar18 grams...
$300.00
0 in stock.View
KCNC 9 Speed Cassette, Shimano
Specifications Weight, 11-32 172 grams Weight, 11-34 178 grams Weight, 12-25 130 grams Weight, 12-27 138 grams Weight, 12-34 185 grams ...
$280.00  $210.00
Save: $70.00 off
1 options.View
KCNC BB30 Road Adapter Bottom Bracket
Specifications Weight 118 grams Bearing Size 6805 (2) Use road, cross country Detail These bottom brackets from KCNC are designed to adapt...
$40.00
2 options.View
KCNC BB86 Adapter
Specifications Weight92 grams Crankset CompatibilityShimano Hollowtech II, KCNC K-Type Bearing Size6805 w7 (2) Material6061 T6 aluminum Detail BB86...
$40.00
0 in stock.View
KCNC BE1 Mountain Bar Ends
Specifications Weight 51 grams Material 7075 aluminum Details KCNC's lightweight bar ends are designed with a contoured CNC machined shape with...
$70.00
5 options.View
KCNC BE2 Mountain Bar Ends
Specifications Weight62 grams Body Material6061 aluminum Bolt Materialstainless steel Clamp Diameter22.2 mm Detail KCNC's BE2 bar ends feature the...
$36.00
1 options.View
KCNC Bottle Cage Bolts
Specifications Weight 2.5 grams/set Material 7075 aluminum Details KCNC's lightweight bottle cage bolts are made from 7075 aluminum, and are...
$10.00
6 options.View
KCNC C6 Road Brake Set
Specifications Weight 224 grams, complete Details KCNC's C6 brakes are made of 6061 aluminum, and offer a dual-pivot design that aids in providing...
$180.00
6 options.View
KCNC C7 Road Brake Set
Specifications Weight170 grams per pair Pad Reach40-55 mm Brake PadsSwiss Stop Flash Pro GHPII Color OptionsBlack, Red, Gold, Silver Detail The C7...
$330.00
4 options.View
KCNC Campagnolo Chainring Bolts
Specifications Weight 10 grams Details KCNC chainring bolts for Campagnolo Ultra Torque cranksets. These KCNC Chainring bolts are specific to...
$22.00
6 options.View
KCNC Centerlock Adapter
Specifications Weight29 grams Material6061 aluminum Detail These centerlock adapters from KCNC are designed to allow the use of standard ISO 6-bolt...
$45.00
5 options.View
KCNC Ceramic Pulley Wheel
Specifications Weight8.5 grams Material7075 aluminum Bearing Size689, hybrid ceramic Available Sizes10, 11, 12, 13 tooth Available Colorsblack,...
$35.00
14 options.View
KCNC DLC Derailleur Cable
Specifications Weight14 grams Materialstainless steel CoatingNano-Diamond Teflon Length2100 mm Diameter1.1 mm Detail KCNC has made a dramatic...
$30.00
2 in stock.View
KCNC DLC Mountain Brake Cable
Specifications Weight24 grams Materialstainless steel CoatingNano-Diamond Teflon Length1700 mm Diameter1.5 mm Detail KCNC has made a dramatic...
$25.00
20 in stock.View
KCNC DLC Road Brake Cable
$25.00
1 in stock.View
KCNC Double Chainring Bolts
Specifications Weight 10 grams Details Anodized 7075 aluminum chainring bolts. Laser-etched with the KCNC logo. Includes five standard...
$16.00
6 options.View
KCNC EVA Foam Grips
Specifications Weight per Pair 15 grams Detail KCNC's EVA foam grips provide a semi-ergonomic, lightweight perch for your hands. They are sold in...
$10.00
5 options.View
KCNC Expander Plug
Specifications Weight 35 grams Material 6061 aluminum Details The KCNC Expander Plug is a lightweight expanding/compression plug which is...
$20.00
5 options.View
KCNC Ferrules
Specifications Material7050 Alloy ColorsBlack, Blue, Gold, Green, Red Size4mm, 5mm Package contains150 ferrules Detail Kcnc aluminum ferrules,...
$110.00
10 options.View
KCNC Front Derailleur Clamp
Specifications Weight 15 grams Material 6061 aluminum Available Sizes 28.6, 31.8, 34.9 mm Detail These front derailleur clamps, manufactured...
$15.00
13 options.View
KCNC Hollow Headset Spacers
Through boring out channels along the height of the spacer, KCNC has managed to drop half the weight of a traditional aluminum spacer. These might be...
$3.00
22 options.View
KCNC I-Spec Shifter Clamps
Specifications Weight15 grams per pair CompatibilityXTR M-980-I, XT M-780-I Clamp Material7075 aluminum Bolt Materialtitanium Detail I-Spec is...
$30.00
5 options.View
KCNC K-Type Road Crankset
Specifications Weight715 grams Available Lengths170, 172.5, 175 BCD130 Standard, 110 Compact Bottom Bracket68mm English, 70mm Italian Detail KCNC's...
$375.00
7 options.View
KCNC K-Type XC2 Double Crankset
KCNC's K-Type crankset / bottom bracket combo features a 3-piece design with an oversize scandium spindle and outboard bearings. This design is not...
$375.00
3 options.View
KCNC K-Type XC2 Triple Crankset
KCNC's K-Type crankset / bottom bracket combo features a 3-piece design with an oversized scandium spindle and outboard bearings. This design is not...
$375.00
4 options.View
KCNC K2 Road Crankset
Specifications Weight 664grams Crank Arm Length 165, 170, 172.5, 175, 177.5, 180 mm Crank Arm Material 7075 aluminum Spindle Material...
$405.00  $303.75
Save: $101.25 off
2 options.View
KCNC K2 XC Triple Crankset
$405.00  $303.75
Save: $101.25 off
1 options.View
KCNC K2 XC2 Double Crankset
Specifications Weight 674 grams Crank Arm Length 170, 175 mm Crank Arm Material 7075 aluminum Spindle Material Scandium Available Colors...
$405.00  $303.75
Save: $101.25 off
4 options.View
KCNC K3 Cobweb Mountain Chainrings
Specifications Weight, 64 BCD 24t19 grams Weight, 64 BCD 26t23 grams Weight, 64 BCD 27t25 grams Weight, 64 BCD 29t26 grams Weight, 64 BCD 30t28...
$46.00
11 options.View
KCNC K3 Cobweb Road Chainrings
Specifications Weight, 110 BCD 34t30 grams Weight, 110 BCD 50t82 grams Weight, 110 BCD 39t33 grams Weight, 110 BCD 53t71 grams Weight, 130 BCD 39t33...
$55.00
10 options.View
KCNC KC01 10 Speed Chain
Specifications Weight266 grams Materialsteel Dimension1/2" x 11/128" Pin Width6.0 mm Length116 links CompatibilityShimano, Campagnolo, Sram 10 speed...
$65.00
7 in stock.View
KCNC Knife SS Pedals
The Knife, KCNC's micro platform pedal, may not be for everyone, but it's impressive nonetheless. A pair of these may find themselves as well suited...
$155.00
3 options.View
KCNC Knife Titanium Pedals
$215.00
3 options.View
KCNC Majestic Seat Mast
Specifications Diameter34.9mm Lengths:75mm, 120mm Offset:0mm, 25mm Colors:Black, Gold, Red, Silver Weight:88-121 grams Material7075 Detail Kcnc...
$115.00
8 options.View
KCNC Morion M1 Headset
1-1/8 inch integrated headset. AL 6061 crown race. Bearing dimension: O.D. 41mm. Angular contact is 45 degrees Height 6.5mm Ti-DLC/Ceramic cartridge...
$325.00
3 options.View
KCNC Morion M2 Headset
1-1/8 inch semi-integrated head set. AL 6061 head tube race. 44mm upper & lower head tube insertion diameter. Ti-DLC/ Ceramic cartridge bearing....
$325.00
1 options.View
KCNC Morion M3 Headset
Specifications Weight, Complete46 grams Weight, w/o top cap and bolt36.5 grams Headset Standardthreadless 1 1/8" external BearingsCeramic / Ti-DLC...
$325.00
3 options.View
KCNC Mountain Chain Catcher
Specifications Weight23 grams Material7075 aluminum CompatibilityShimano, KCNC cranksets Detail KCNC' mountain chain catcher is designed to deflect...
$34.00
5 options.View
KCNC Mountain Chainrings
Specifications Weight - 22t/24t 18 grams Weight - 32t/34t 34 grams Weight - 44t 87 grams Material 7075 aluminum Detail A...
$30.00
7 options.View
KCNC PF BB41 Mountain Bottom Bracket
Specifications Weight95 grams BB Shell Fit, Inner Diameter41 mm BB Shell Fit, Width89.5, 92.0 mm Crankset CompatibilityShimano Hollowtech II, KCNC...
$40.00
0 in stock.View
KCNC Presta Valve Caps
Specifications Material7075 Alloy Weight1.2 grams per pair FitsPresta Valves ColorsBlack, Blue, Gold, Green, Red, Silver Detail Anodized Kcnc...
$6.50
6 options.View
KCNC Pulley Bolt Set
KCNC's new derailleur pulley bolt is yet another way to customize the look of your bike, while shedding a bit of weight. The replacement pulley bolts...
$10.00
6 options.View
KCNC Pump Head
Specifications Valve compatibility Presta only Detail KCNC's pump head provides a great aftermarket upgrade option for the most common...
$40.00
0 in stock.View
KCNC Radiant KR1 1.125-1.5" Tapered Headset
Weight69 grams Bearingsstainless steel cartridge, angular contact SHIS FitIS41/28.6|IS52/40 Steerer Compatibilitytapered, 1-1/8" - 1-1/2" (1.125" -...
$135.00
5 options.View
KCNC Radiant R1 Headset
Specifications Weight62 grams Steerer Compatibility1-1/8" (1.125") Bearingstainless steel cartridge, angular contact Bearing OD41 mm x 45 deg Stack...
$120.00
6 options.View
KCNC Radiant R2 Headset
1-1/8 Semi-integrated headset. AL 6061 head tube races. 44mm upper & lower head tube insertion diameter. Stainless steel cartridge bearings....
$120.00
6 options.View
KCNC Radiant R3 Headset
1-1/8 inch threadless headset. AL6061 crown race. 34mm upper & lower head tube insertion diameter. Stainless steel bearings with TiN finished...
$120.00
6 options.View
KCNC Radiant R4 Headset
1-1/2 inch threadless headset. AL6061 crown race. 49.65mm upper & lower head tube insertion diameter. Stainless steel bearings with TiN...
$180.00
4 options.View
KCNC Razor Disc Brake Rotor
Specifications Weight, 140 mm62 grams Weight, 160 mm74 grams Weight, 180 mm95 grams Materialstainless steel Detail Razor rotors push the limits of...
$25.00
3 options.View
KCNC Road Bar Plugs
Specifications Weight 26 grams Material 6061 aluminum Details Fully CNC machined 6061 aluminum bar end plugs for your road bike. These KCNC...
$20.00
6 options.View
KCNC Road Chain Catcher
Specifications Weight w/ Hardware19 grams Material7075 aluminum Bolt Materialstainless steel Compatibilitybraze-on derailleurs Detail KCNC's chain...
$32.00
6 options.View
KCNC Road Chainrings
Specifications Weight - 34t 33 grams Weight - 50t 100 grams Weight - 39t 40 grams Weight - 53t 88 grams Material 7075...
$44.00
4 options.View
KCNC Road Lite Seatpost Collar, 35.6
The KCNC Road Lite collar, is similar to the SC9 and SC11 collars, but utilizes a ti binder bolt in order to achieve incredibly light weights without...
$26.00
6 in stock.View
KCNC Roller Bearing Bottom Bracket
Specifications Weight 128 grams Material 6061 Al Details KCNC's roller bearing bottom bracket is designed for intensive and heavy-duty usage....
$60.00
2 options.View
KCNC Rotor by Ashima
Specifications Weights 85 grams, 105 grams, 130 grams Available Diameters 160 mm, 180 mm, 203 mm Detail KCNC disc brake rotors, manufactured...
$25.00
1 options.View
KCNC SC Bone 15 mm Rise Mountain Bar
Specifications Weight, 31.8 mm 237 grams Weight, 25.4 mm 224 grams Length 710 mm Stem Clamp Diameters 25.4 mm, 31.8 mm ...
$75.00
2 options.View
KCNC SC Bone Flat Mountain Bar
Scandium T - 7451 Dia: 25.4 or 31.8 Width: 600mm Rise: 0 Bend: 5°  For XC use. Weight : 115g
$70.00
2 options.View
KCNC SC Pro Lite Seatpost
Specifications Weight, 27.2 x 350175 grams Weight, 27.2 x 400188 grams Weight, 30.9 x 350206 grams Weight, 30.9 x 400214 grams Weight, 31.6 x 350203...
$100.00
6 options.View
KCNC SC10 QR MTB Seatpost Collar
KCNC's SC10 mountain quick release seat collar features a unique bushing-less spherical cam. This system ensures consistently smooth and powerful...
$26.00
11 options.View
KCNC SC11 MTB Seatpost Collar
Specifications Weight, 31.8 mm10.5 grams Weight, 34.9 mm11.5 grams Weight, 36.4 mm13.0 grams Weight, 38.2 mm13.5 grams Weight, 39.0 mm12.5 grams...
$24.00
15 options.View
KCNC SC9 Road Seatpost Collar
Ready for a simple, inexpensive upgrade? The KCNC SC9 seatpost collar may be exactly what you're looking for. Starting at a mere 12 grams for the...
$24.00
8 options.View
KCNC Shimano HTII Crank Bolt
Specifications Weight4.5 grams Threadm30 x 8 Material6061 aluminum ColorsBlack, Blue, Gold, Green, Red, Silver CompatibilityShimano Hollowtech II,...
$8.00
6 options.View
KCNC Single Speed Chainring Bolts
Specifications Weight 7.5 grams/set Material 7075 aluminum Details KCNC's single speed chainring bolts offer an affordable and attractive means...
$16.00
6 options.View
KCNC Steady Pedals
The "Steady" is KCNC's wide platform pedal, suitable for use in BMX and cross country. Replaceable semi sharp steel pins help provide grip and...
$155.00
3 options.View
KCNC Teflon Derailleur Cable
Specifications Cable Material:Stainless Steel Coating:Teflon Colors:Blue, Green, Orange, Pink, Red, White Length:2100mm Diameter:1.1mm Weight:14.5...
$7.00
6 options.View
KCNC Teflon Mountain Brake Cable
Specifications Weight24 grams Materialstainless steel CoatingNano-Diamond Teflon Length1700 mm Diameter1.5 mm Detail KCNC's coated cables begin...
$7.00
4 options.View
KCNC Teflon Road Brake Cable
Specifications Cable Material:Stainless Steel Coating:Teflon Colors:Blue, Green, Orange, Pink, Red, White Length:1700mm Diameter:1.5mm Weight:20...
$7.00
6 options.View
KCNC Ti Pro Lite Seatpost
The Ti Pro Lite is KCNC's lightweight zero-setback seatpost. The main tube is machined scandium alloy, while the upper hardware consists of 7075...
$110.00
22 options.View
KCNC Titanium DLC Pulley Wheel
Specifications Weight (without bolt)8.2 grams Tooth Count11 Pulley MaterialDLC coated 6/4titanium Bearing689, full ceramic Detail KCNC gets...
$150.00
0 in stock.View
KCNC Titanium Mountain Skewers
Specifications Weight46 grams Lever MaterialAl 7075 Axle Material6/4 titanium Colorsblack, blue, gold, green, red, silver Detail Mountain Bikers...
$72.00
6 options.View
KCNC Titanium Road Skewers
Specifications Weight46 grams Lever MaterialAl 7075 Axle Material6/4 titanium Colorsblack, blue, gold, green, red, silver Detail The KCNC quick...
$72.00
6 options.View
KCNC Ultra Pulley Wheel
Specifications Weight, 10 tooth6.6 grams Weight, 11 tooth6.9 grams Material7075 aluminum Bearing687 ,steel Available Sizes10, 11 tooth Detail Each...
$18.00
12 options.View
KCNC V-Brake Pad Holders
Specifications Weight 33 grams Cartridge Brake Shoe Set 72mm Construction M7 scandium alloy Bolts Compatibility XT, XTR, KCNC VB1, and most...
$33.00
1 in stock.View
KCNC V6 Linear Pull Brake Set
Specifications Weight, Complete Set 312 grams Weight, Calipers 123 grams Weight, Lever Set 66 grams Vertical Pad Reach 15-40 mm Acceptable...
$290.00
6 options.View
KCNC Valve Extenders
Specifications Weight, 50 mm2.2 grams each Weight, 85 mm4.2 grams each Valve CompatibilityPresta Detail KCNC's lightweight valve extenders are a...
$12.00
7 options.View
KCNC VB1 Brake Lever Set
Specifications Weight per Pair48 grams Material7075 aluminum Lever End to Pivot92 mm Bar Clamp Diameter22.2 mm Detail KCNC's VB1 brake levers are...
$140.00
0 in stock.View
KCNC XTR Double Chainring Conversion
Specifications Material7075 Alloy FitsXTR M980 ColorsBlack, Gold, Red Detail With the growing popularity of double chainrings, lots of people are...
$30.00
3 options.View
KCNC YBN 9 Speed Chain
Specifications Weight270 grams Materialsteel Dimension1/2" x 11/128" Pin Width6.6 mm Length116 links CompatibilityShimano, Sram 9 speed Detail...
$55.00
2 options.View
KCNC Z6 Steel Mountain Skewers
Specifications Weight 65 grams Material 6061 aluminum lever, steel axle Details In addition to offering the 44g titanium axle skewer set, KCNC...
$38.00
6 options.View
KCNC Z6 Steel Road Skewers
Specifications Weight 65 grams Material 6061 aluminum, steel Details In addition to offering the 44g titanium axle skewer set, KCNC has also...
$38.00
6 options.View
KCNC WB1 TT Aero Brake Lever
Specifications Weight70 grams per pair Material7075 aluminum Expander Adjustment Range18.0 - 22.0 mm Brake Cable Compatibilityroad Detail KCNC's...
$150.00
3 options.View
KCNC Road Brake Pad Holders
Specifications Weight22.2 grams per pair CompatibilityShimano-style calipers PadsSwiss Stop Flash Pro - GHPII Holder Material7075 aluminum Bolt...
$35.00
3 options.View
KCNC Arrow Stem
Specifications Weight, 100 mm135 grams Weight, 110 mm140 grams Weight, 120 mm142 grams Weight, 130 mm145 grams Material7050 aluminum Available...
$90.00
10 options.View
KCNC Fly Ride Road Stem (26.0 mm)
Specifications Weight 124 grams Lengths 70mm, 80mm, 90mm, 100mm, 110mm, 120mm Angle +/-5 degrees Clamp Diameter 26.0 mm Material CNC'd...
$45.00
6 options.View
KCNC Fly Ride Stem (31.8mm)
Specifications Weight 124 grams Lengths 50mm, 60mm, 70mm, 80mm, 90mm, 100mm, 110mm, 120mm Angle +/-5 degrees Clamp Diameter 31.8 mm ...
$45.00
9 options.View
KCNC Team Issue Stem (31.8mm)
Specifications Weight 100mm 103 grams Lengths 80mm, 90mm, 100mm, 110mm, 120mm Angle +/-5 degrees Clamp Diameter 31.8 mm Stack Height 38 mm...
$90.00
5 options.View
KCNC Ti Pro Mountain Stem (25.4mm)
Specifications Weight 110mm 113 grams Lengths 80mm, 90mm, 100mm, 110mm Angle +/-5 degrees Clamp Diameter 25.4 mm Steerer Diameter 28.6 mm ...
$90.00
4 options.View
KCNC Ti Pro Road Stem (26.0mm)
Specifications Weight 110mm 113 grams Lengths 80mm, 90mm, 100mm, 110mm Angle +/-5 degrees Clamp Diameter 26.0 mm Steerer Diameter 28.6 mm ...
$90.00
5 options.View
