KCNC Low Profile Bottle Cage Bolts
Sign Up For Our Newsletter
You're Signed Up!
Weight per pair2.1 grams
ThreadM5 x 15 mm
Torx FittingT25
Material7075 aluminum
KCNC Low Profile Bottle Cage Bolts Black $10.00 In Stock
KCNC Low Profile Bottle Cage Bolts Blue $10.00 In Stock
KCNC Low Profile Bottle Cage Bolts Gold $10.00 In Stock
KCNC Low Profile Bottle Cage Bolts Green $10.00 In Stock
KCNC Low Profile Bottle Cage Bolts Red $10.00 In Stock
KCNC Low Profile Bottle Cage Bolts Silver $10.00 In Stock
Details
KCNC designed these bottle cage bolts sets to be versatile, light weight, and attractive. The low profile button heads are a mere 2.5 mm tall, making them compatible with nearly every available bottle cage design. The long 15 mm threads also allow these bolts to be used with frame spacers or in other situations where a longer bolt is necessary. A T25 Torx wrench is required to install or remove the bolt, and a pair of stainless steel washers is included.
Comment on KCNC Low Profile Bottle Cage Bolts
