Kcnc Knife Stainless Steel Pedals
$155.00
The Knife, KCNC's micro platform pedal, may not be for everyone, but it's impressive nonetheless. A pair of these may find themselves as well suited to a micro mini BMX bike as to a high-end road commuter bike, or as a solution for riders who shun the clip-less status quo. At a mere 60 mm long by 50 mm wide, this platform pedal is inherently light weight, but just large enough to provide a stable perch for the ball of your foot. Replaceable semi sharp steel pins help provide grip and inspire confidence. Internally, a needle bearing and standard sealed cartridge bearing share the work of keeping the pedal spinning smooth. Additional seals are installed on either end of the pedal body to keep the dirt and moisture out. The 7075 aluminum pedal body is cleverly and attractively machined to form KCNC's signature "K" logo. Finish anodizing is available in bright gold or glossy black.
This stainless steel spindled version of the Knife pedal, while heavier than its titanium counterpart, is functionally similar and more affordable. The spindle is given special TiN (titanium nitride) coating to improve wear life against the pedal's needle bearing. This treatment gives the steel surface a durable gold sheen.
Includes a tool for installation and removal of steel pins.
Weight184 grams per pair
Material7075 aluminum
Length60 mm
Width50 mm
