KCNC Kasditor Disc Rotor
Sign Up For Our Newsletter
You're Signed Up!
Material7075 AL
stainless
Compatibility6 bolt ISO
Rotor Thickness1.8 mm
IncludesRotor and hardware
Weights
140 mm67 grams
160 mm77 grams
180 mm94 grams
KCNC Kasditor Disc Rotor 140 mm, Black $45.00 In Stock
KCNC Kasditor Disc Rotor 140 mm, Blue $45.00 In Stock
KCNC Kasditor Disc Rotor 140 mm, Gold $45.00 In Stock
KCNC Kasditor Disc Rotor 140 mm, Green $45.00 In Stock
KCNC Kasditor Disc Rotor 140 mm, Red $45.00 In Stock
KCNC Kasditor Disc Rotor 160 mm, Black $45.00  1 Remaining
KCNC Kasditor Disc Rotor 160 mm, Blue $45.00 In Stock
KCNC Kasditor Disc Rotor 160 mm, Gold $45.00 In Stock
KCNC Kasditor Disc Rotor 160 mm, Green $45.00 In Stock
KCNC Kasditor Disc Rotor 160 mm, Red $45.00 In Stock
KCNC Kasditor Disc Rotor 180 mm, Black $53.00 In Stock
KCNC Kasditor Disc Rotor 180 mm, Blue $53.00 In Stock
KCNC Kasditor Disc Rotor 180 mm, Gold $53.00 In Stock
KCNC Kasditor Disc Rotor 180 mm, Green $53.00 In Stock
KCNC Kasditor Disc Rotor 180 mm, Red $53.00 In Stock
Details
The expert designers and machinists at KCNC are renowned for their ability to create utilitarian parts with a unique and bold aesthetic. In that same vein, allow us to introduce the Kasditor disc brake rotor. Borrowing from their previous tried and true minimalist rotor designs, KCNC has added a few more features to make the Kasditor even more appealing. By utilizing a beautifully machined 7075 aluminum spider and an aggressively laser cut rotor, the Kasditor inherits a handful of highly desirable characteristics. With the use of a 7075 alloy spider, each rotor is exceptionally light, while simultaneously remaining incredibly stiff to maintain constant and precise braking during long descents. Similar to a floating rotor, the 7075 spider additionally allows for better heat management for more reliable brake operation.
Compatibility
The KCNC Kasditor rotor is compatible with all 6 bolt ISO hub and brake designs, unless specified otherwise by the manufacturer.
