KCNC K3 Cobweb Road Chainrings
KCNC K3 Cobweb Road Chainrings Black, 110 BCD, 34 Tooth $55.00  1 Remaining
KCNC K3 Cobweb Road Chainrings Black, 110 BCD, 39 Tooth $55.00 Notify Me When Available
KCNC K3 Cobweb Road Chainrings Black, 110 BCD, 50 Tooth $90.00 Notify Me When Available
KCNC K3 Cobweb Road Chainrings Black, 110 BCD, 53 Tooth $90.00 Notify Me When Available
KCNC K3 Cobweb Road Chainrings Black, 130 BCD, 39 Tooth $55.00  2 Remaining
KCNC K3 Cobweb Road Chainrings Black, 130 BCD, 44 Tooth $90.00 In Stock
KCNC K3 Cobweb Road Chainrings Black, 130 BCD, 52 Tooth $90.00 In Stock
KCNC K3 Cobweb Road Chainrings Black, 130 BCD, 53 Tooth $90.00 Notify Me When Available
KCNC K3 Cobweb Road Chainrings Red, 110 BCD, 34 Tooth $55.00 In Stock
KCNC K3 Cobweb Road Chainrings Red, 110 BCD, 50 Tooth $90.00 In Stock
KCNC K3 Cobweb Road Chainrings Red, 130 BCD, 39 Tooth $55.00 In Stock
KCNC K3 Cobweb Road Chainrings Red, 130 BCD, 52 Tooth $90.00 In Stock
KCNC K3 Cobweb Road Chainrings Red, 130 BCD, 53 Tooth $90.00 In Stock
Weight, 110 BCD 34t30 grams
Weight, 110 BCD 50t82 grams
Weight, 110 BCD 39t33 grams
Weight, 110 BCD 53t71 grams
Weight, 130 BCD 39t33 grams
Weight, 130 BCD 52t83 grams
Weight, 130 BCD 53t80 grams
MaterialT73 7075 aluminum
UseRoad
K3 Cobweb chainrings from KCNC offer a lightweight, visually striking, and functionally sound aftermarket drivetrain option. The design-patented K3 is aggressively machined from a flat sheet of aluminum for maximum weight savings, leaving behind an intricate crisscrossed structure that ensures maximum rigidity from the least possible material. Included in this design are profiled teeth and eight sets of shift ramps and steel pins to provide excellent shifting performance.
KCNC K3 chainrings are available in standard 130 BCD and compact 110 BCD, with compact conversion 39 and 53 tooth chainrings for converting a compact crankset to standard road configuration.
Comment on KCNC K3 Cobweb Road Chainrings
