KCNC K3 Cobweb Mountain Chainrings
KCNC K3 Cobweb Mountain Chainrings 104 BCD, 36 Tooth, Outer$94.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 104 BCD, 38 Tooth, Outer$94.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 104 BCD, 40 Tooth, Outer$94.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 104 BCD, 42 Tooth, Outer$94.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 64 BCD, 24 Tooth, Inner$46.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 64 BCD, 26 Tooth, Inner$52.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 64 BCD, 27 Tooth, Inner$56.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 64 BCD, 29 Tooth, Inner$62.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 64 BCD, 30 Tooth, Inner$66.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 94 BCD, 29 Tooth, Inner$84.00 Notify Me When Available
KCNC K3 Cobweb Mountain Chainrings 94 BCD, 40 Tooth, Outer$94.00 Notify Me When Available
Weight, 64 BCD 24t19 grams
Weight, 64 BCD 26t23 grams
Weight, 64 BCD 27t25 grams
Weight, 64 BCD 29t26 grams
Weight, 64 BCD 30t28 grams
Weight, 104 BCD 36t47 grams
Weight, 104 BCD 38t52 grams
Weight, 104 BCD 40t50 grams
Weight, 104 BCD 42t55 grams
Weight, 94 BCD 29t20 grams
Weight, 94 BCD 40t57 grams
MaterialT73 7075 aluminum
Usecross country; double
K3 Cobweb chainrings from KCNC offer a lightweight, visually striking, and functionally sound aftermarket drivetrain option. The design-patented K3 is aggressively machined from a flat sheet of aluminum for maximum weight savings, leaving behind an intricate crisscrossed structure that ensures maximum rigidity from the least possible material. Included in this design are profiled teeth and six sets of shift ramps and steel pins to provide excellent shifting performance.
KCNC K3 mountain chainrings are designed for double ring drivetrains, and are available in a wide gearing range to allow maximum suitability for different riders and wheel sizes. KCNC provides these chainrings in two bolt pattern options: 4-bolt, 64/104 BCD and 5 bolt, 94 BCD.
Comment on KCNC K3 Cobweb Mountain Chainrings
