KCNC K2 XC2 Double Crankset
KCNC K2 XC2 Double Crankset 170mm Black 42/29$405.00  $303.75
Save: $101.25 off
 1 Remaining
KCNC K2 XC2 Double Crankset 175mm Black 40/26$405.00  $303.75
Save: $101.25 off
In Stock
KCNC K2 XC2 Double Crankset 175mm Black 42/29$405.00  $303.75
Save: $101.25 off
 2 Remaining
KCNC K2 XC2 Double Crankset 175mm Gold 42/29$405.00  $303.75
Save: $101.25 off
Notify Me When Available
Weight 674 grams
Crank Arm Length 170, 175 mm
Crank Arm Material 7075 aluminum
Spindle Material Scandium
Available Colors Black, Red, Gold
Chainrings 42/29, 40/27, 40/26, 38,26 94 mm BCD
Bearing Size 6805 w7
The K2-Type crankset from KCNC is the next evolution of their lightweight K-Type design. This outboard bearing three piece crankset features a lightweight hollow scandium spindle paired with KCNC's patented dual-channel hollow 7075 aluminum crank arms. The striking, disc style Blade chainrings are mounted with KCNC's popular aluminum chainring bolts. All are manufactured from the same light and strong 7075 aluminum material. This design is not only lightweight, but strong and stiff as well.
The K2 features a double chainring setup designed for 9 and 10 speed mountain drivetrains. The outer 42 tooth chainring is equipped with ramps and steel pins for smoother shifting. The bottom bracket is compatible with English threaded 68 and 73 mm wide shells.
Detailed installation instructions are included. Required tools include a Shimano style outboard bearing tool, and 2.5 mm and 8 mm hex wrenches.
Comment on KCNC K2 XC2 Double Crankset
