KCNC K2 Road Crankset
KCNC K2 Road Crankset 172.5, Compact 50/34, Black$405.00  $303.75
Save: $101.25 off
Notify Me When Available
KCNC K2 Road Crankset 172.5, Compact 50/34, Red$405.00  $303.75
Save: $101.25 off
 1 Remaining
Weight 664grams
Crank Arm Length 165, 170, 172.5, 175, 177.5, 180 mm
Crank Arm Material 7075 aluminum
Spindle Material Scandium
Available Colors Black, Red, Gold
Chainrings 50/34, 53/39 110 or 130 mm BCD
Bearing Size 6805 w7
The K2-Type crankset from KCNC is the next evolution of their lightweight K-Type design. This outboard bearing three piece crankset features a lightweight hollow scandium spindle paired with KCNC's patented dual-channel hollow 7075 aluminum crank arms. The striking, disc style Blade chainrings are mounted with KCNC's popular aluminum chainring bolts. All are manufactured from the same light and strong 7075 aluminum material. This design is not only lightweight, but strong and stiff as well.
The K2 features a double chainring setup designed for road drivetrains. The outer chainring is equipped with ramps and steel pins for smoother shifting. The bottom bracket is compatible with English threaded shells.
Detailed installation instructions are included. Required tools include a Shimano style outboard bearing tool, and 2.5 mm and 8 mm hex wrenches.
Comment on KCNC K2 Road Crankset
