KCNC I-Spec Shifter Clamps
KCNC I-Spec Shifter Clamps Black$30.00 Notify Me When Available
KCNC I-Spec Shifter Clamps Blue$30.00 Notify Me When Available
KCNC I-Spec Shifter Clamps Gold$30.00 In Stock
KCNC I-Spec Shifter Clamps Red$30.00 Notify Me When Available
KCNC I-Spec Shifter Clamps Silver$30.00 Notify Me When Available
Weight15 grams per pair
CompatibilityXTR M-980-I, XT M-780-I
Clamp Material7075 aluminum
Bolt Materialtitanium
I-Spec is Shimano's system for integrating their flat bar shifters and brake levers into a clean and simple single bar clamp. For riders wishing to use a non-Shimano brake system with their I-Spec equipped shifters, this presents a problem, since the integrated bar clamp is located on the brake lever. KCNC's I-Spec adapters are designed to solve this problem by converting I-Spec shifters to a standard independent clamp while adding a bit of flair in the process.
Comment on KCNC I-Spec Shifter Clamps
