KCNC Grooving Road Skewers
KCNC Grooving Specs
Weight 35 grams
Cam Travel 1.73mm
Lever Material Al 7075
Rod Material Machined 6/4 Titanium
Rod Length 158 rear, 124 front
Colors Black
KCNC Grooving Road Skewers Black $95.00 Notify Me When Available
KCNC Grooving Road Skewers Red $95.00 In Stock
KCNC Grooving Road Skewers Gold $95.00 Notify Me When Available
KCNC Grooving Road Skewers Blue $95.00 In Stock
KCNC Grooving Road Skewers Green $95.00  1 Remaining
The Grooving Road Skewer is KCNC's latest skewer. With little to improve on over the already light 42g Titanium Road Skewer KCNC made one subtle change to shed another seven grams. Simply put they machined four grooves into the axle giving it the cross section of a plus ( + ) sign. The other changes are simply for aesthetic purposes. The logos on the handle are now a gold color instead of silver and the axle rod itself has a gold tint.
The good thing about the Grooving skewer is that unlike some improved and lightened products this second version did away with nothing we already liked about the original. The ball and socket design is still smooth and both interfaces are both metal. This means that the skewer will have a significantly longer lifetime than something with a plastic cup although it might need a bit of lube everynow and then. The handle is not a milimeter too long, very quick and efficient for a wheel change.
Comment on KCNC Grooving Road Skewers
