KCNC Front Derailleur Clamp
KCNC Front Derailleur Clamp 28.6 mm, Black$15.00 Notify Me When Available
KCNC Front Derailleur Clamp 31.8 mm, Black$15.00 In Stock
KCNC Front Derailleur Clamp 31.8 mm, Blue$15.00 In Stock
KCNC Front Derailleur Clamp 31.8 mm, Gold$15.00 In Stock
KCNC Front Derailleur Clamp 31.8 mm, Green$15.00 In Stock
KCNC Front Derailleur Clamp 31.8 mm, Red$15.00  1 Remaining
KCNC Front Derailleur Clamp 31.8 mm, Silver$15.00 Notify Me When Available
KCNC Front Derailleur Clamp 34.9 mm, Black$15.00 Notify Me When Available
KCNC Front Derailleur Clamp 34.9 mm, Blue$15.00 In Stock
KCNC Front Derailleur Clamp 34.9 mm, Gold$15.00  2 Remaining
KCNC Front Derailleur Clamp 34.9 mm, Green$15.00 In Stock
KCNC Front Derailleur Clamp 34.9 mm, Red$15.00  1 Remaining
KCNC Front Derailleur Clamp 34.9 mm, Silver$15.00 In Stock
Weight 15 grams
Material 6061 aluminum
Available Sizes 28.6, 31.8, 34.9 mm
These front derailleur clamps, manufactured by KCNC, are designed to adapt braze-on style front derailleurs to standard diameter seat tubes. This design integrates the clamping bolt and derailleur mounting bolt to simplify things and save a little weight. Compared to a standard Shimano adapter clamp, these are 15 grams lighter.
Beyond standard derailleur placement and adjustment, installation of the KCNC derailleur clamp only requires use of the derailleur's mounting bolt. Once tightened, the clamp and derailleur are both secured.
