KCNC Fly Ride Stem (31.8mm)
KCNC Fly Ride Stem (31.8mm) 5 Degree 50mm$45.00  1 Remaining
KCNC Fly Ride Stem (31.8mm) 5 Degree 60mm$45.00  1 Remaining
KCNC Fly Ride Stem (31.8mm) 5 Degree 70mm$45.00 In Stock
KCNC Fly Ride Stem (31.8mm) 5 Degree 80mm$45.00 In Stock
KCNC Fly Ride Stem (31.8mm) 5 Degree 90mm$45.00 In Stock
KCNC Fly Ride Stem (31.8mm) 5 Degree 100mm$45.00 In Stock
KCNC Fly Ride Stem (31.8mm) 5 Degree 110mm$45.00  2 Remaining
KCNC Fly Ride Stem (31.8mm) 5 Degree 120mm$45.00 In Stock
KCNC Fly Ride Stem (31.8mm) 5 Degree 130mm$45.00  2 Remaining
Weight 124 grams
Lengths 50mm, 60mm, 70mm, 80mm, 90mm, 100mm, 110mm, 120mm
Angle +/-5 degrees
Clamp Diameter 31.8 mm
Material CNC'd 6061 Aluminum
Clamp 4 bolt, 31.8 diameter
Finish Black and silver anodized with laser-cut logos
Hardware Steel bolts and washers
KCNC's line of Fly Ride stems are lightweight, strong, and reasonably priced.
For Road or XC use only.
Comment on KCNC Fly Ride Stem (31.8mm)
