KCNC Fly Ride Road Stem (26.0 mm)
KCNC Fly Ride Road Stem (26.0 mm) 5 Degree 70mm$45.00  2 Remaining
KCNC Fly Ride Road Stem (26.0 mm) 5 Degree 80mm$45.00  2 Remaining
KCNC Fly Ride Road Stem (26.0 mm) 5 Degree 90mm$45.00 In Stock
KCNC Fly Ride Road Stem (26.0 mm) 5 Degree 100mm$45.00  1 Remaining
KCNC Fly Ride Road Stem (26.0 mm) 5 Degree 110mm$45.00  1 Remaining
KCNC Fly Ride Road Stem (26.0 mm) 5 Degree 120mm$45.00  1 Remaining
Weight 124 grams
Lengths 70mm, 80mm, 90mm, 100mm, 110mm, 120mm
Angle +/-5 degrees
Clamp Diameter 26.0 mm
Material CNC'd 6061 Aluminum
Clamp 4 bolt, 26.0 diameter
Finish Black and silver anodized with laser-cut logos
Hardware Steel bolts and washers
KCNC's line of Fly Ride stems are lightweight, strong, and reasonably priced.
For Road or XC use only.
Comment on KCNC Fly Ride Road Stem (26.0 mm)
