KCNC Ceramic Pulley Wheel Black 10t
$35.00
KCNC's pulleys are intentionally designed with an integral amount of "float," or lateral movement. This movement allows the pulley to settle into an optimum postition under each cassette cog. The result is faster, smoother shifts and a quieter drivetrain. In our experience, these are the best-shifting after market pulleys available, past or present.
Each KCNC pulley wheel is equipped with a high quality hybrid ceramic cartridge bearing. The advantages of using a ceramic bearing in the rear derailleur's pulleys are the most dramatic of any other bicycle bearing system. This is due to the high speed at which the pulleys spin - often as high as 600 RPM.
This 10 tooth pulley is machined from light and strong 7075 aluminum and black-anodized, with laser cut logos.
Sold as an individual pulley. Compatible with all Campagnolo, SRAM (road and X-0), and Shimano rear derailleurs. (Campy derailleurs come equipped with 10 tooth pulleys, SRAM and Shimano come equipped with 11 tooth pulleys).
Weight: 8.5g
Add to Cart:
  • Model: KCN21326694K
  • Manufactured by: KCNC
Current Reviews: 1
Copyrighted © by Fairwheel Bikes   All Rights Reserved.
Zen Cart customization by Pushing Buttons Az
Minor Theme Customization by Potent Products
