KCNC CB3 Brake
KCNC CB3 Brake
KCNC CB3 Brake
KCNC CB3 Brake
KCNC CB3 Brake
KCNC CB3 Brake
Sign Up For Our Newsletter
You're Signed Up!
Material Machined 7075 Aluminum
Weight 170 grams per pair*
Pad Reach 40-55 mm
Max Rim Width27 mm
Brake Pads Swiss Stop Flash Pro BXP
Color Options Black
*Including pads and holders
KCNC CB3 Brake Black $334.38 In Stock
Details
KCNC's CB3 introduces a unique improvement to the already popular C7 road brake. The cage surrounding the brake is not purely aesthetic, it increases the stiffness of the brake while decreasing flex during braking. This decrease in flex translates into an improvement in modulation.
The CB3 uses a symmetric dual pivot design, similar to the C7, maintaining the performance and adjustability of that system. The CB3 however, guided by the external cage introduces much less flex in both the pivots and the brake arm itself.
To properly install the CB3 brake set, cable and housing cutters, as well as 3 mm and 4 mm hex wrenches, are required. KCNC provides five different length mounting nuts for maximum frame and fork compatibility. Detailed installation instructions are provided with purchase. We recommend that these brakes be installed by an experienced mechanic.
