KCNC Campagnolo Chainring Bolts
Weight108 grams
12 grams per set
Material7075 aluminum
Contents
Stepped Sleeved Nuts (4)M6, 6.7 mm sleeve
Stepped Bolts (4)M6 x 4.5 mm
Sleeved Crank Arm Bolt (1)M8 x 6.4 mm, 10 x 8 mm sleeve
Chainring Spacer3.8 mm, 10 mm ID
KCNC Campagnolo Chainring Bolts Black $22.00 Notify Me When Available
KCNC Campagnolo Chainring Bolts Blue $22.00 In Stock
KCNC Campagnolo Chainring Bolts Gold $22.00 In Stock
KCNC Campagnolo Chainring Bolts Green $22.00 Notify Me When Available
KCNC Campagnolo Chainring Bolts Red $22.00 Notify Me When Available
KCNC Campagnolo Chainring Bolts Silver $22.00 In Stock
KCNC’s Ultra Torque chainring bolt sets are an inexpensive replacement option for worn or damaged stock bolts. Additionally, they may be purchased as an upgrade for color tuning a Campagnolo crankset. These chainring bolts are expertly machined from high quality 7075 aluminum and attractively finished in six color options.
Compatibility
Please note that these chainring bolts have limited compatibility, due to Campagnolo’s continually evolving standards. KCNC’s Campagnolo Chainring Bolt Set is compatible only with pre-2012 Ultra Torque cranksets. Please contact us before ordering if you are unsure that these chainring bolts will work for you.
To avoid accidental loosening, we recommend that KCNC Campagnolo chainring bolts be installed with a medium-strength threadlock compound. In the absence of threadlocker, light grease may be used. When using a torque wrench, tighten each chainring bolt to a maximum of 7 Nm (62 in-lbs).
Comment on KCNC Campagnolo Chainring Bolts
