KCNC C7 Road Brake Set
KCNC C7 Road Brake Set Black$330.00 Notify Me When Available
KCNC C7 Road Brake Set Gold$330.00 In Stock
KCNC C7 Road Brake Set Red$330.00 In Stock
KCNC C7 Road Brake Set Silver$330.00  2 Remaining
Weight170 grams per pair
Pad Reach40-55 mm
Brake PadsSwiss Stop Flash Pro GHPII
Color OptionsBlack, Red, Gold, Silver
The C7 road brake caliper set from KCNC is a stiffer, more powerful version of their popular, lightweight, and price competitive CB1 brake set. Added design features and changes from the CB1 model have substantially increased performance, yet resulted in a negligible weight increase.
The C7 uses a unique symmetric dual pivot design with incorporated roller bearing guide pins. This guide pin design represents the most substantial improvement over the CB1, which utilizes a single pin with no bearing. Additionally, the left pivot arm has increased in size and stiffness, and the release lever now has a larger platform for easier use.
KCNC C7 brakes now include Swiss Stop's high performance GHPII brake pads for the best possible balance betweeen wear life, modulation, and stopping power.
To properly install the C7 brake set, cable and housing cutters, as well as 3 mm and 4 mm hex wrenches, are required. KCNC provides five different length mounting nuts for maximum frame and fork compatibility. Detailed installation instructions are provided with purchase. We recommend that these brakes be installed by an experienced mechanic.
