KCNC BB30 Road Adapter Bottom Bracket
KCNC BB30 Road Adapter Bottom Bracket Black$40.00 In Stock
KCNC BB30 Road Adapter Bottom Bracket Gold$40.00  1 Remaining
KCNC BB30 Road Adapter Bottom Bracket Red$40.00  2 Remaining
Weight 118 grams
Bearing Size 6805 (2)
Use road, cross country
These bottom brackets from KCNC are designed to adapt BB30 bottom brackets for use with common 24 mm spindle, 68 mm shell-compatible cranksets such as Shimano's Hollowtech II series and FSA's Gossamer crankset. Two extra plastic bearing caps are included with each adapter.
To properly tighten these threaded bearing cups, two Hollowtech II compatible tools will be required. KCNC recommends tightening the cups to 35 ft-lbs of torque. This design uses a compressible o-ring on the non-drive side cup to compensate for bottom bracket width discrepancies.
Comment on KCNC BB30 Road Adapter Bottom Bracket
