KCNC Arrow Stem
KCNC Arrow Stem Black, 17 deg, 140 mm$90.00  1 Remaining
KCNC Arrow Stem Black, 7 deg, 80 mm$90.00 In Stock
KCNC Arrow Stem Black, 7 deg, 90 mm$90.00 In Stock
KCNC Arrow Stem Black, 7 deg, 100 mm$90.00  2 Remaining
KCNC Arrow Stem Black, 7 deg, 110 mm$90.00  1 Remaining
KCNC Arrow Stem Black, 7 deg, 120 mm$90.00  1 Remaining
KCNC Arrow Stem Black, 7 deg, 130 mm$90.00  1 Remaining
KCNC Arrow Stem Black, 17 deg, 110 mm$90.00 Notify Me When Available
KCNC Arrow Stem White, 17 deg, 110 mm$90.00  1 Remaining
KCNC Arrow Stem Black, 17 deg, 120 mm$90.00 Notify Me When Available
KCNC Arrow Stem White, 17 deg, 120 mm$90.00  1 Remaining
KCNC Arrow Stem Black, 17 deg, 130 mm$90.00  1 Remaining
KCNC Arrow Stem White, 17 deg, 130 mm$90.00 Notify Me When Available
Weight, 100 mm135 grams
Weight, 110 mm140 grams
Weight, 120 mm142 grams
Weight, 130 mm145 grams
Material7050 aluminum
Available Lengths110, 120, 130mm
Available Rises+/- 7 degree, +/- 17 degree
Handlebar clamp31.8mm
Bolt Material6/4 titanium
Available Colorsblack, white
KCNC's Arrow stem is geared specifically toward the racer or sport enthusiast who desires a stiff stem without taking a weight penalty. This stem's wide, octagonally shaped body is expertly machined from 7050 series aluminum in a way that yields an impressive stiffness-to-weight ratio. Six titanium clamping bolts help save additional weight. Arrow stems are given an attractive high gloss finish, available in either anodized black or powdercoated white.
Comment on KCNC Arrow Stem
