KCNC 15MM Thru Axle
KCNC 15MM Thru Axle
KCNC 15MM Thru Axle
KCNC 15MM Thru Axle
KCNC 15MM Thru Axle
KCNC 15MM Thru Axle
Sign Up For Our Newsletter
You're Signed Up!
Weight 53.3 grams
Material Hard Anodized
7075 Aluminum
Compatibility Fox Racing Fork
KCNC 15MM Thru Axle Black $100.00  1 Remaining
KCNC 15MM Thru Axle Blue $100.00 In Stock
KCNC 15MM Thru Axle Gold $100.00 In Stock
KCNC 15MM Thru Axle Green $100.00  1 Remaining
KCNC 15MM Thru Axle Red $100.00 In Stock
KCNC 15MM Thru Axle Silver $100.00 In Stock
If you want to replace your 15mm thru axle and save a few grams without sacrificing durability, KCNC’s offering might be what you’re looking for. Built from 7075 aluminum, the 15mm axle is sturdy enough for most off-road applications. A quick release style mechanism clamps down on the non-threaded fork end. The aluminum construction also means it comes in anodized colors to add a bit of flash to your ride. Note: Only compatible with Fox Racing Forks which require a 15mm thru axle.
Comment on KCNC 15MM Thru Axle
