KCNC 12mm X 142mm Skewer
Sign Up For Our Newsletter
You're Signed Up!
Weight 42.1 grams
Material Hard Anodized
7075 Aluminum
Compatibility Shimano / DT-Swiss
12mm X 142mm
KCNC 12mm X 142mm Skewer DT Swiss, Black $100.00 In Stock
KCNC 12mm X 142mm Skewer DT Swiss, Green $100.00 In Stock
KCNC 12mm X 142mm Skewer DT Swiss, Red $100.00 In Stock
KCNC 12mm X 142mm Skewer Shimano, Black $100.00 In Stock
Details
KCNC's handsomely machined, and exceptionally light rear 12 x 142 mm thru axle skewer. CNC machined from 7075 aluminum and hard anodized for durability that can withstand the rigors of typical mountain bike abuse. The hollow axle uses the already popular and proven ball and socket joint to close the lever that all other KCNC skewers use, insuring an iron grip on your dropout. Add a dash of color to your build while simultaneously shaving precious grams.
Compatibility
These 12mm X 142mm quick release skewers are designed to be compatible with either the Shimano E-Thru or DT Swiss standards. Please purchase accordingly.
