KCNC 10 Speed Chain
KCNC 10 Speed Chain
KCNC 10 Speed Chain
KCNC 10 Speed Chain
KCNC 10 Speed Chain
KCNC 10 Speed Chain Specs
Weight 266 grams
Material steel
Dimension 1/2" x 11/128"
Pin Width 6.0 mm
Length 116 links
Compatibility Shimano, Campagnolo, Sram 10 speed
KCNC 10 Speed Chain Gold $65.00  1 Remaining
KCNC 10 Speed Chain Silver $65.00 In Stock
These lightweight steel chains are manufactured for KCNC by the chain specialist company PYC, and are stamped with KCNC's "K" logo. Each chain features hollow yet strong chromized pins, relieved inner and outer plates, and chamfered plate edges for the best possible performance. The chains' plates are titanium nitride treated for longer wear life and are gold in appearance. The hollow pins and bushingless rollers are untreated and silver in appearance.
Included is a two piece master link for convenient assembly and disassembly. This link may be removed by hand, but is more easily removed using a quick link separator such as the KMC Link Remover Tool . A chain rivet tool is required to correctly size the chain upon initial installation.
Comment on KCNC 10 Speed Chain
