IoDupont
Power Cordz 5 mm Housing Segment
Specifications Weight38 grams per meterLength1 meterOuter Diameter5 mm Detail This housing segment is provided by Power Cordz as an extension to...
$10.00
1 in stock.View
Power Cordz Brake Cable Set
Closeout - Colored MTB Brake Cordz 20% Discount! Specifications Weight 5 grams per cable Colors black, blue, red, white, yellow Diameter 1.75...
$37.00  $29.60
Save: $7.40 off
7 options.View
Power Cordz Brake System Prime
Specifications Weight, complete mountain system95 gramsWeight, complete road system85 grams Contents 2 ea - 1.75mm brake Cordz 1 ea - pre-lubed 5mm...
$79.00
4 options.View
Power Cordz Derailleur Cable Set
Closeout - 1.5 mm Derailleur Cordz 20% Discount! Specifications Weight, 1.2 mm5.3 grams/pairWeight, 1.5 mm8.2 grams/pairLength2 meters Detail...
$37.00  $29.60
Save: $7.40 off
8 options.View
Power Cordz Derailleur System
Closeout - 5 mm Derailleur System 20% Discount! Details Experience the next generation of cycling cable control systems! IoDupont's Power Cordz...
$68.00  $54.40
Save: $13.60 off
4 options.View
Power Cordz Nokon Liner
Contains 3 - two meter long sections of liner Details Until recently, it was not possible to use PowerCordz brake cables with Nokon housing systems....
$12.00
0 in stock.View
Power Cordz Windsor Brake Clasps
Specifications Weight 2.0 grams per pair Compatibility (5mm, 6mm) All Campagnolo and SRAM Force brake calipers, as well as many aftermarket...
$11.00
3 options.View
