Ice Toolz
Ice Toolz 15 mm Pedal Wrench
This 15 mm pedal wrench, manufactured from durable Cr-Mo steel, is designed to fit any pedal with 15 mm wrench flats. This wrench's minimal 4mm width...
$10.00
0 in stock.View
Ice Toolz 3/32" Chain Whip
This inexpensive yet durable 3/32" chain whip from Ice Toolz is designed for use with any multi-speed cassette, from 6 to 11 speed. Combined with the...
$9.00
0 in stock.View
Ice Toolz 7-10 Speed Chain Tool
This consumer-level chain tool from Ice Toolz is designed for use with 7, 8, 9, and 10 speed Shimano compatible chains, and uses a 1.5 link shelf to...
$12.00
1 in stock.View
Ice Toolz 7-10 Speed Pro Chain Tool
This professional quality chain tool from Ice Toolz features a patented design on par with the best chain tools available. Compatibility includes all...
$25.00
2 options.View
Ice Toolz Bottom Bracket Tapping and Facing Tool
Fastest, easiest tool to use on the market. Aligns, cleans, and faces the bottom bracket. Can be used on steel or aluminum shells (1.370"x24TPI...
$175.00
0 in stock.View
Ice Toolz Bottom Bracket Tapping and Facing Tool, Italian
Fastest, easiest tool to use on the market. Aligns, cleans, and faces the bottom bracket. Can be used on steel or aluminum shells (36mmx24TPI...
$175.00
0 in stock.View
Ice Toolz Cable and Housing Cutters
Pro shop cable and spoke cutter, SIS SP durability rated, case hardened. Contains patented inner wire and outer casing conditioner. Patented.
$42.00
0 in stock.View
Ice Toolz Chain Checker
This stainless steel go/no-go chain checker operates in a simple, foolproof fashion. The side of the tool is etched with these simple instructions:...
$9.50
0 in stock.View
Ice Toolz Chain Master
The Ice Toolz Chain Master is designed for rear chainstay, dropout, and derailleur protection when you travel. Additionally, this patented device...
$8.00
0 in stock.View
Ice Toolz Chainring Nut Driver Tool
Professional tool for chainring bolt installation, Cr-V steel. No more cracking your knuckles during operation.
$5.00
0 in stock.View
Ice Toolz Cr-V Combo Wrench Set
This set of highly polished Chromium Vanadium combination wrenches includes 8 wrenches in millimeter increments from 8 to 15 mm. Each tool features a...
$50.00
1 in stock.View
Ice Toolz Crown Race Installation Tool
Faster, safer, and more precise crown race installation tool. Unique patented centerline sleeve guide allows you to precisely align any model fork...
$70.00
1 in stock.View
Ice Toolz Headset & Bottom Bracket Press Tool
Headset cup / BB cup press tool, up to 1-1/2”. For head tube length up to 260mm.
$120.00
0 in stock.View
Ice Toolz Headset Cup Removal Tool
Headset cup remover for cups sized 1", 1-1/8", and 1-1/4".
$20.00
0 in stock.View
Ice Toolz Headset Press
Fastest, easiest tool to use, aligns and presses any headset for fool proof installation. Step bushing for any headset size, also 1 pc. BB Sets...
$100.00
0 in stock.View
Ice Toolz Internal Nipple Wrench
These high quality internal nipple spoke wrenches are manufactured from SNCM steel with a high impact plastic handle. The 115 mm long extension will...
$8.00
3 options.View
Ice Toolz Lateral Spoke Wrench
These lateral spoke wrenches from Ice Toolz allow for easier building and truing of wheels with light gauge bladed spokes or stubborn, frozen...
$7.00
3 options.View
Ice Toolz Octalink / ISIS BB Tool
This high quality, CNC engineered bottom bracket tool is compatible with Shimano Octalink, ISIS, and many other inboard bearing bottom brackets. It...
$9.00
0 in stock.View
Ice Toolz Outboard Bearing BB Tool
This BB cup removal / installation tool is compatible with Shimano Hollowtech II, Campagnolo Ultra-Torque, and outboard bearing bottom brackets from...
$13.00
0 in stock.View
Ice Toolz Saw Guide
No home mechanic's toolbox would be complete without a saw guide, such as this model from Ice Toolz. Designed for use with all common bicycle tubing...
$38.00
0 in stock.View
Ice Toolz Shimano Cassette Lockring Tool
This cassette tool, manufactured from Cr-V steel, is compatible with Shimano style lockrings, as well as lockrings for center lock disc brake rotors....
$7.00
0 in stock.View
Ice Toolz Spoke Wrench
Ice Toolz' spoke wrenches feature a standard, proven design with Cr-Mo construction and coated handles. They are available in two sizes: 0.127" to...
$5.00
2 options.View
Ice Toolz Star Nut Installation Tool
Allows precise alignment of any star nut will work on 1” & 1-1/8” steerers. Perfect for high use shop environment.
$15.00
2 in stock.View
Ice Toolz Tap Set
Complete set of frame and pedal taps (8-taps) with E-161 handle securely packaged in a professional carrying case.
$50.00
1 in stock.View
Ice Toolz Tire Lever Set
Ice Toolz' Nylon/Fiberglass composite tire levers are strong, but not too strong, to allow easy tire removal without fear of scratching or otherwise...
$3.50
0 in stock.View
Ice Toolz Xpert Torque Wrench
Every year, more components are being made with advanced lightweight materials that require precise installation. Know exactly when you have achieved...
$53.00
2 options.View
