Road Hubs
Specifications Weight 66 grams Bearing Size 6900 (2) Axle Diameter 12 mm Available Drillings 16, 20, 24, 28, 32 hole Available Colors...
$180.0012 options.View
Specifications Weight 222 grams Bearing Sizes 6903, 6804, 6807, 6803 (2) Axle Diameter 17/20 mm Available Drillings 20, 24, 28, 32, 36 hole ...
$420.0015 options.View
Specifications Weight100 grams Bearing Sizeproprietary hybrid ceramic Axle Diameter17 mm Available Drillings20, 24, 28, 32 hole Available...
$229.002 options.View
Specifications Weight217 grams Bearing Sizeproprietary hybrid ceramic Axle Diameter16.5 mm Available Drillings24, 28, 32 hole Available Colorsblack,...
$449.002 options.View
Specifications Weight102 grams Bearing Sizeproprietary stainless steel Axle Diameter17 mm Available Drillings20, 24, 28, 32 hole Available...
$169.0010 options.View
Specifications Weight218 grams Bearing Sizeproprietary stainless steel Axle Diameter16.5 mm Available Drillings24, 28, 32 hole Available...
$369.0010 options.View
Specifications Weight109 grams Bearings6803 (2) Wheel Building Dimensions Flange Diameter38.8 mm Flange to Center37.3 mm Detail DT's...
$200.004 options.View
Specifications Weight, Shimano220 grams Weight, Campagnolo210 grams Bearing Sizes6902 (2), 6802 (2) Axle Diameter15 mm Available Drillings24, 28, 32...
$415.006 options.View
Detail DT Swiss offers freehub kits for their 240s series hubs. These kits allow simple, tool-free conversion between Campagnolo and...
$85.002 options.View
Specifications Weight64 grams Bearing Size6803 Drilling Options16, 18, 20, 24, 28, 32 hole Hub Shell Material7075 aluminum Wheel Building...
$180.002 options.View
Specifications Weight47 grams Bearing Size6801 Available Drillings16, 20, 24 hole Hub Shell Material7075 aluminum Wheel Building Dimensions ...
$210.002 options.View
Specifications Weight49 grams Bearing Size6801 (2) Axle Diameter14 mm Available Drillings16, 18, 20, 24 hole Hub Shell Material7075tx aluminum...
$210.003 options.View
Specifications Weight139 grams Bearing Size6803 (2), 6903 (1) Axle Diameter17 mm Available Drillings20, 24, 28 hole Hub Shell Material7075 aluminum...
$480.003 options.View
Specifications Weight133 grams Bearing Size6803 (2), 6903 (1) Axle Diameter17 mm Available Drillings20, 24, 28 hole Hub Shell Material7075 aluminum...
$550.002 options.View
Specifications Weight135 grams Bearing Size6803 (2), 6903 (1) Axle Diameter17 mm Available Drillings20, 24, 28 hole Hub Shell Material7075 aluminum...
$480.006 options.View
Specifications Weight74 grams Bearing Size6803 (2) Axle Diameter17 mm Available Drillings20, 24 hole Hub Shell Materialaluminum Useroad, time trial,...
$95.002 options.View
Specifications Weight, Shimano214 grams Weight, Campagnolo194 grams Bearing Size, Shimano6903 (4) Bearing Size, Campagnolo6903 (2), 6803 (2) Axle...
$305.003 options.View
Specifications Weight, Shimano195 grams Weight, Campagnolo186 grams Bearing Size6902 (2), 6802 (2) Wheel Build Specifications Left Flange...
$300.00 $225.00Save: $75.00 off
1 options.View
Specifications Weight170 grams Bearings6803 (1), 6903 (1), 6803 (2) Axle Diameter17 mm Available Drillings24, 28 hole Hub Shell Material7075...
$380.0010 options.View
Specifications Weight187 grams Bearings6802 (1), Tune XOT (1), 6902 (1) Material7075 aluminum Available Drillings20, 24, 28, 32 hole Available...
$340.00 $238.00Save: $102.00 off
1 options.View
In order to properly load spokes into the Tune Mig 45's flanges, the carbon axle must be removed and then reinstalled using a specially-designed...
$245.002 options.View
Specifications Weight75 grams Bearings6802 (2)Shell Material7075 aluminum Wheel Building Dimensions Flange Diameter37.5 mm Flange to Center35...
$160.0013 options.View
Specifications Weight 95 grams Bearing Size 6901 (2) Axle Diameter 12 mm Available Drillings 20, 24, 28, 32 hole Available Colors black,...
$130.008 options.View
Specifications Weight 249 grams Bearing Sizes 6902 (3), 6802 (2) Axle Diameter 15 mm Available Drillings 24, 28, 32 hole Available Colors...
$265.0012 options.View
