Mountain Hubs
Weight 330g (QR Axle) Bearing Size Proprietary Stainless Steel Axle Diameter 19.5mm Frame Compatibility 135mm Quick Release 135 x 10mm TA 135 x...
$389.004 options.View
Weight 165g (QR Axle) Bearing Size Proprietary Stainless Steel Axle Diameter 19.5mm Fork Compatibility Quick Release 15mm Thru Axle Available...
$199.005 options.View
Specifications Weight 68 grams Material 7075 aluminum Bearing Sizes 6803 (2) Available Spoke Drillings 24, 28, 32 Detail The Extralite...
$270.005 options.View
Specifications Weight84 gramsBearing Size6902 (1), 6805 (2)Available Drillings28, 32 holeHub Shell Material7075tx aluminumCompatibilityCannondale...
$270.003 options.View
Specifications Weight 168 grams Material 7075 aluminum Bearing Sizes 6803x2, 6903x2 Available Spoke Drillings 28, 32 Detail The Extralite...
$600.004 options.View
The Extralite UltraFront SPD hub is one of the lightest disc hubs ever at 98g. The front and rear hubs come in at an astonishing 296g, which allows...
$234.00 $163.80Save: $70.20 off
0 in stock.View
Specifications Weight128 gramsBearing Size6903 (2)Axle Diameter17 mmBody and Axle Material7075 T6 aluminum Wheel Building Specifications Left...
$145.00 $108.75Save: $36.25 off
1 options.View
Specifications Weight118 gramsBearing Size6902, 6805Hub Shell Material7075 T6 aluminumAvailable Spoke Drillings28, 32 hole Wheel Build...
$120.00 $90.00Save: $30.00 off
1 options.View
Specifications Weight245 gramsBearing Size6903 (4)Axle Diameter17 mmBody and Axle Material7075 T6 aluminum Wheel Building Specifications Left...
$335.00 $251.25Save: $83.75 off
1 options.View
Specifications Weight 99 grams Material 7075 aluminum Bearing Sizes 6802, 6805 Available Spoke Drillings 28, 32 Wheel Building...
$220.007 options.View
Specifications Weight115 gramsBearing Size6803 (2)Axle Diameter17 mmShell, Axle Material7075 aluminumDisc Mount6 bolt ISOAvailable Drillings28, 32...
$220.009 options.View
Specifications Weight205 gramsBearing Size6803 (1), 6903 (1), 6803 (2)Axle Diameter17 mmAvailable Drillings28, 32 holeDisc MountingISO 6-bolt Wheel...
$440.008 options.View
Kong X-12 Details CompatibilityX-12 (142+) Weight208 grams Bearing Size6803 (1), 6903 (1), 6803 (2) Axle Diameter17 mm Available Drillings28, 32 hole...
$440.003 options.View
Specifications Weight105 gramsBearing Size6803 (2)Axle Diameter17 mmShell, Axle Material7075 aluminumDisc Mount6 bolt ISOAvailable Drillings28, 32...
$330.001 options.View
The Singlespeeder fits the needs of the weight conscious singlespeeder. You can get rid of that heavy disc hub and heavy, ovaled freewheel that...
$600.002 options.View
