HSC
Specifications Weight45 gramsBearings6805w7 (2) Si3N4 Ceramic hybridCup MaterialaluminumShell CompatibilityBB30 (68mm wide, 42 mm ID)Crankset...
$120.0010 in stock.View
Specifications Fits:All BB30Weight:54gramsBearing:Si3N4 Ceramic hybrid Detail HSC Ceramic bearing bottom bracket for BB30 One of the smoothest and...
$140.0010 in stock.View
Specifications Weight44 gramsMaterialdelrin thermoplasticBB CompatibilityBB30, PF30Crankset CompatibilityShimano Hollowtech II Detail Shimano is one...
$50.002 in stock.View
Specifications Weight54 gramsBearings6805w7 (2) Si3N4 Ceramic hybridCup Materialdelrin thermoplasticShell Compatibility86.5 mm wide, 41 mm IDCrankset...
$120.006 in stock.View
Specifications Bearing ID OD Width 600010 mm26 mm8 mm6088 mm22 mm7 mm6099 mm24 mm7 mm680112 mm21 mm5 mm680215 mm24 mm5 mm680317 mm26 mm5 mm680420...
$15.0014 options.View
Specifications Weight84 gramsBearings6805 Si3N4 Ceramic hybridAvailable Threading1.37" x 24 tpi (English, BSA) 36 mm x 24 tpi (Italian)Crankset...
$110.008 options.View
Specifications RacesABEC 5 ZrO2 ZirconiaBallsSi3N4 Silicon Nitride, grade 3Cageinjection molded polyamideSealsdual lip labrinth, rubber Bearing ID ...
$90.006 options.View
Specifications Weight74 gramsBearings6806 (2) Si3N4 Ceramic hybridCup Materialdelrin thermoplasticShell Compatibility68 and 73 mm wide PF30 Detail...
$120.0013 in stock.View
