HSC BB30 Reducer Sleeves
In Stock
$50.00
Add to Cart:
Weight44 grams
Materialdelrin thermoplastic
BB CompatibilityBB30, PF30
Crankset CompatibilityShimano Hollowtech II
Shimano is one of the few manufacturers who has yet to embrace a 30 mm bottom bracket spindle standard, and for BB30 frame owners who wish to equip Shimano cranksets, this creates a compatibility problem. With their BB30 bottom bracket reducers sleeves, HSC presents a simple solution to this problem. These CNC machined delrin plastic reducers lightly press in to an existing BB30 or PF30 bottom bracket to simulatneously widen the bottom bracket and reduce the spindle interface to allow full compatibility with Shimano Hollowtech II cranksets.
Ordering
These reducers contain no bearings and merely retrofit an existing bottom bracket; an alternative solution for frames without bottom bracket bearings installed is an HSC BB30 Adapter Bottom Bracket. Feel free to contact us directly for technical questions.
Installation/Assembly
No special tools are required to install the reducer shims; they can be easily pressed in by hand.
