Hsc BB30 Ceramic Bottom Bracket
HSC
$120.00
HSC, the leading name in ceramic bearing upgrades for almost any cycling application, have created a niche for themselves by producing high quality, performance tuned aftermarket bearing options. By utilizing ultra smooth Si3N4 bearings coupled with stainless steel races, HSC is able to create a bearing system with surprisingly little friction, and phenomenal wear life.
If you find yourself desiring better performance from your OEM bottom bracket, or it's simply time to replace a worn out bearing set, the HSC ceramic BB30 option is an excellent choice.
We highly recommend your HSC ceramic BB30 bottom bracket be installed by a professional shop that uses a proper bearing press, to ensure maximum performance and wear life.
Frame Compatibility All BB30
Crank Compatibility BB30
Weight 54 grams
Contents 2 ceramic bearings, 2 dust shields, 2 retaining clips, and 1 wave spacer
