HSC BB Right Press Fit Bottom Bracket
Sign Up For Our Newsletter
You're Signed Up!
Weight, Shimano99 g
Weight, Sram102 g
BearingsGRD 3 hybrid ceramic
Cup MaterialAluminum
HSC BB Right Press Fit Bottom Bracket Shimano Hollowtech 24mm $120.00 Notify Me When Available
HSC BB Right Press Fit Bottom Bracket Sram/Truvativ BB30 $120.00 Notify Me When Available
Details
The HSC ceramic bottom bracket is an excellent choice if you're looking to upgrade your current stock BB. Utilizing hybrid ceramic bearings, the HSC bottom bracket results in less friction, and longer wear life than your typical stainless steel BB.
Manufactured to work with the Cervelo designed BBRight system, the cups are CNC machined out of aluminum to ensure proper tolerances for an accurate press fit.
Compatibilty
With the correct option, the HSC BBRight bottom bracket will work with either Shimano hollowtech 24 mm cranksets, or Sram/Truvativ BB30 cranksets. Adapter cups are not needed with either bottom bracket.
Comment on HSC BB Right Press Fit Bottom Bracket
