Hed Belgium C2 Clincher Rim
HED
$130.00
HED's Belgium C2 rims are one of our top picks for custom built wheels, and are quite possibly the finest aluminum clincher rims available. Using strict manufacturing tolerances and good quality control, HED has produced a near perfectly round rim with extremely parallel machined braking surfaces. Using such tight tolerances allows for wheel builds with better spoke tension balance, increasing the longevity of the build. A nearly imperceptible welded rim seam and wide cross section ensure a high strength-to-weight ratio and maxiumum wheel life. Prior to machining, the rim surface is bead blasted and black anodized for a clean, elegant look. The applied Belgian flag decals are reflective for added safety when riding in low light situations.
An additional benefit of the Belgium's wide 23 mm sidewalls is improved tire performance. Spreading the tire beads allows a tire to keep a more consistently round profile, improving ride quality, aerodynamics, and cornering response. Wide road tires and cyclocross tires are also more safely mounted on wider profile rims.
Weight 470 grams
Outer Width 23 mm
Internal Width 17.5 mm
Depth 24 mm
Material aluminum alloy
Available Drillings 24, 28, 32 hole
Tire Compatibility 700c clincher (ISO 622)
ERD 592 mm
  1. Great, thanks for sharing this article post.Thanks Again. Really Cool. Helmy
    Posted by WilliamErar
    Great, thanks for sharing this article post.Thanks Again. Really Cool. Gagon
  2. The standard for alloy rims
    Posted by Mike C.
    I've been riding these rims for 3 years now and they are still true and have no obvious signs of wear. A little heavier than other options but it is a set it and forget rim.
