HED Belgium C2 Clincher Rim
HED Belgium C2 Clincher Rim 20 Hole$120.00 Notify Me When Available
HED Belgium C2 Clincher Rim 24 Hole$120.00 Notify Me When Available
HED Belgium C2 Clincher Rim 28 Hole$120.00 Notify Me When Available
HED Belgium C2 Clincher Rim 32 Hole$120.00 Notify Me When Available
Weight470 grams
Width23 mm
Depth24 mm
Materialaluminum alloy
Available Drillings24, 28, 32 hole
Tire Compatibility700c clincher (ISO 622)
ERD592 mm
HED's Belgium C2 rims are one of our top picks for custom built wheels, and are quite possibly the finest aluminum clincher rims available. Using strict manufacturing tolerances and good quality control, HED has produced a near perfectly round rim with extremely parallel machined braking surfaces. Using such tight tolerances allows for wheel builds with better spoke tension balance, increasing the longevity of the build. A nearly imperceptible welded rim seam and wide cross section ensure a high strength-to-weight ratio and maxiumum wheel life. Prior to machining, the rim surface is bead blasted and black anodized for a clean, elegant look. The applied Belgian flag decals are reflective for added safety when riding in low light situations.
An additional benefit of the Belgium's wide 23 mm sidewalls is improved tire performance. Spreading the tire beads allows a tire to keep a more consistently round profile, improving ride quality, aerodynamics, and cornering response. Wide road tires and cyclocross tires are also more safely mounted on wider profile rims.
Assembly
We recommend that wheels built with HED rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly or submit a custom wheel build request here.
Comment on HED Belgium C2 Clincher Rim
