Headsets
Cane Creek AER Headset
Specifications Traditional Weight46 grams Top Stack Height7.90 mm Bottom Stack Height12.05 mm Material7075 T6 aluminum Top BearingNorglide X2...
$125.00
4 options.View
Chris King Baseplate
Specifications Weight, Titanium 1-1/8"8 grams Weight, Stainless Steel 1-1/8"14 grams Weight, Stainless Steel 1-1/8" Tall28 grams Weight, Stainless...
$12.00
4 options.View
Chris King InSet Headset
Specifications Weight90 grams Steerer Compatibility1 1/8" straight Stack Height12.7 mm Headtube Bore44.0 mm Description InSet is Chris King's entry...
$135.00
3 options.View
Chris King NoThreadSet 1.5"
The Chris King 1.5" NoThreadSet features the same legendary features if the 1 1/8" NoThreadSet, but in an over-sized package. The 1.5" NoThreadSet...
$170.00
0 in stock.View
Chris King NoThreadSet Headset 1-1/8"
Over 30 years ago, Chris King designed the first sealed bearing headset. Since then, King Precision Components has earned its current reputation for...
$135.00
15 options.View
Extralite Delrin Headset Spacers
Extralite's Extrabolt 10 headset spacer kit for 1-1/8" steerer tubes. Includes two 5mm and one 10mm spacers. Artistically machined from strong and...
$25.00
6 in stock.View
Extralite Head 2 Headsets
Extralite infuses every bit of their artistry and mechanical creativity into all the products they create, and their line of headsets is no...
$160.00
3 options.View
Extralite Top Cap w/ Aluminum Bolt
Specifications Weight4.6 grams Bolt DimensionsM6 x 20 Detail This is the top cap included with every Extralite headset - expertly machined from...
$35.00
7 options.View
Extralite Ultrastar 2 Expander
Specifications Weight7 grams Compatible Steerer Tube I.D.23.3-25.2 mm Material7075 T6 aluminum Useroad, cross country Detail The latest iteration...
$40.00
6 in stock.View
Fair Wheel "Shoot Out" Top Caps
Specifications Weight 6 grams Detail These limited edition Fair Wheel Bikes top caps are carefully machined, anodized, and laser etched for maximum...
$12.50
9 options.View
Fair Wheel "Sonoran Desert" Top Caps
$12.50
6 options.View
Fair Wheel Logo Top Caps
Specifications Weight355 grams Boltm6 x 35 Material7075 aluminum Detail These top caps feature Geoff McFetridge designed Fair Wheel logos, laser...
$12.50
5 options.View
Far and Near Headset Spacers
Specifications Weight, 3 mm 3 gramsWeight, 5 mm 5 grams Weight, 8 mm 8 grams Inner Diameter 28.6 mm (1.125") Outer Diameter 36.2 mm ...
$2.00
10 options.View
Fibre-Lyte Carbon Top Cap
Fibre-Lyte's carbon top cap for 1-1/8" threadless headsets. Requires an M6 countersunk bolt (not included). Available in 1k and 3k carbon weave...
$15.00
2 options.View
KCNC Expander Plug
Specifications Weight 35 grams Material 6061 aluminum Details The KCNC Expander Plug is a lightweight expanding/compression plug which is...
$20.00
5 options.View
KCNC Hollow Headset Spacers
Through boring out channels along the height of the spacer, KCNC has managed to drop half the weight of a traditional aluminum spacer. These might be...
$3.00
22 options.View
KCNC Morion M1 Headset
1-1/8 inch integrated headset. AL 6061 crown race. Bearing dimension: O.D. 41mm. Angular contact is 45 degrees Height 6.5mm Ti-DLC/Ceramic cartridge...
$325.00
3 options.View
KCNC Morion M2 Headset
1-1/8 inch semi-integrated head set. AL 6061 head tube race. 44mm upper & lower head tube insertion diameter. Ti-DLC/ Ceramic cartridge bearing....
$325.00
1 options.View
KCNC Morion M3 Headset
Specifications Weight, Complete46 grams Weight, w/o top cap and bolt36.5 grams Headset Standardthreadless 1 1/8" external BearingsCeramic / Ti-DLC...
$325.00
3 options.View
KCNC Radiant KR1 1.125-1.5" Tapered Headset
Weight69 grams Bearingsstainless steel cartridge, angular contact SHIS FitIS41/28.6|IS52/40 Steerer Compatibilitytapered, 1-1/8" - 1-1/2" (1.125" -...
$135.00
5 options.View
KCNC Radiant R1 Headset
Specifications Weight62 grams Steerer Compatibility1-1/8" (1.125") Bearingstainless steel cartridge, angular contact Bearing OD41 mm x 45 deg Stack...
$120.00
6 options.View
KCNC Radiant R2 Headset
1-1/8 Semi-integrated headset. AL 6061 head tube races. 44mm upper & lower head tube insertion diameter. Stainless steel cartridge bearings....
$120.00
6 options.View
KCNC Radiant R3 Headset
1-1/8 inch threadless headset. AL6061 crown race. 34mm upper & lower head tube insertion diameter. Stainless steel bearings with TiN finished...
$120.00
6 options.View
KCNC Radiant R4 Headset
1-1/2 inch threadless headset. AL6061 crown race. 49.65mm upper & lower head tube insertion diameter. Stainless steel bearings with TiN...
$180.00
4 options.View
Kronos Top Cap
Looking for some colored accessorizing options while shedding a bit of weight? The Kronos Aluminum Top Cap available in Green, Blue, Red, Gold, and...
$10.00  $7.00
Save: $3.00 off
2 options.View
New Ultimate Carbon Headset Spacers
Carbon headset spacers from new ultimate in 10mm heights for 1 1/8" steerer tubes. Weight : 4g (per spacer )
$3.00
2 options.View
Parts of Passion Aluminum Headset Spacer
Specifications Weight 5mm = 1.5 grams 10mm = 3.1 grams 15mm = 4.7 grams MaterialAl 6060 ColorsBlack, Blue, Brown, Gold, Green, Orange, Pink, Purple,...
$5.00
42 options.View
Parts of Passion Aluminum Top Cap
Specifications Weight 7.6 Grams Material Al 7075-T6 Details These new headset top caps are a great way to add a touch of color to your headset!...
$18.00
13 options.View
Parts of Passion Carbon Top Cap
Specifications Weight 4 Grams Material Carbon Fiber Details Superlight carbon fiber topcaps and bolts in a range of styles including UD. At 4...
$22.00
5 options.View
Soul-Kozak Headset Spacers
Ultra machined 7075 aluminum headset spacers. Convex external shape with very thin walls. Black with Soul logo laser etched. 10mm, 3.4grams 15mm,...
$9.00
3 options.View
Soul-Kozak Top-Cap
This is one of the coolest top-cap designs we've encountered. The cap and bolt are one piece of CNC'd 7065 series aluminum. The end result is the...
$27.00
12 in stock.View
Tune Bobo Headset
Tune's conventional headset for road and MTB use. Weighs 79g • Material : cups: 7075 T6 aluminum, cap: carbon. • Construction : conventional aheadset...
$130.00
10 options.View
Tune Bubi Tapered Headset
Specifications Weight89 grams Material, Cups7075 T6 aluminum Stack Height8.9 mm SHIS FitZS44/28.6|ZS56/40 Detail The Tune Bubi is a tapered 1-1/8"...
$200.00
1 options.View
Tune Bubu Semi Integrated Headset
Specifications Weight, Headset Only63.5 grams Weight, Top Cap and Bolt 5.0 grams Weight, Expander9.6 grams Material, Cups7075 T6 Aluminum Stack...
$130.00
2 options.View
Tune Carbon Top Cap & Bolt
The Tune carbon top cap and bolt is the one of lightest such assemblies carried at Fair Wheel Bikes. It is simple, effective, and elegant. The carbon...
$20.00
0 in stock.View
Tune Gum Gum Expander Plug
Specifications Weight9 grams Steerer ID Fit24.0 - 25.5 mm Plate Material7075 T6 aluminum Expander Materialsilicone rubber Detail Tune's Gum Gum is...
$17.00
12 in stock.View
Tune Verhuterli Top Cap
The Tune Verhüterli is designed for use with carbon steerer tubes as a super lightweight replacement for the traditional expander plug, top cap, and...
$27.00
18 in stock.View
