Road Handlebars
Enve Carbon Compact Road Bars
Specifications Weight, 40cm210 gramsWeight, 42cm215 gramsWeight, 44cm220 gramsDrop127 mmReach79 mmStem Clamp31.8 mm Detail Enve's compact carbon road...
$350.00
3 options.View
Enve Carbon Road Bars
Specifications Weight, 42cm205 gramsDrop144 mmReach85 mmStem Clamp31.8 mm Detail Enve's road handlebar design focuses on strength and comfort rather...
$350.00
5 options.View
KCNC Road Bar Plugs
Specifications Weight 26 grams Material 6061 aluminum Details Fully CNC machined 6061 aluminum bar end plugs for your road bike. These KCNC...
$20.00
6 options.View
New Ultimate Aluminum Road Bar
7050 Aluminum Bar from New Ultimate with an ideal ergonomic shape. Flat top with a slight downward slope and a rounded drop. This is one of the most...
$80.00
3 options.View
New Ultimate Carbon Road Bar
Specifications Weight185 gramsMaterialcarbon fiberReach9 cmDrop13 cmStem Clamp31.8 mmAvailable Widths40, 42, 44 cmAvailable Finishesgloss, matte,...
$270.00
7 options.View
Purely Custom Road Handlebar Plugs
Specifications Weight per Pair 23.2 grams Handlebar ID Compatibility 19.0 - 25.0 mm Available Colors black, blue, pink, red Additional...
$22.00
5 options.View
Schmolke SL Carbon Handlebars
Schmolke Carbon was founded in 1993, shortly after Stefan Schmolke constructed the world's first carbon fiber handlebar. In the following years,...
$575.00
3 options.View
Schmolke TLO Compact Carbon Road Handlebars
Specifications Weight~145 gramsStem Clamp Diameter26.0 mmAvailable Widths*40, 42, 44, 46 cmRider Weight Limit75 kg (165 lbs)*measured outside to...
$640.00
6 options.View
Schmolke TLO Compact OS 31.8 Carbon Road Handlebars
Specifications Weight~150 gramsStem Clamp Diameter31.8 mmWidth44 cmRider Weight Limit75 kg (165 lbs)*measured outside to outside Geometry Reach 95...
$640.00
1 options.View
Schmolke TLO Ergo Carbon Road Handlebars
$640.00
6 options.View
Veloflyte Carbon Bar Plugs
Specifications Weight 4.4 Grams/pair Material Carbon Fiber Details Veloflyte's 100% carbon fiber bar end plugs for road bikes are manufactured...
$35.00
0 in stock.View
