Mountain Handlebars
Specifications Weight225 gramsWidth800 mmSweep9 degreesRise23 mmClamp Diameter31.8 mm About Enve Composites In late 2010, Edge Composites announced...
$175.000 in stock.View
Specifications Weight185 gramsMaterialcarbon fiberStem Clamp31.8 mmWidth700 mm (27.5")Back Sweep9 degreesUp Sweep5 degreesRise20 mm About Enve...
$160.000 in stock.View
Specifications Weight175 gramsWidth700 mm (27.5")Sweep9 degreesRise0 Detail We believe Enve Composite's mountain handlebars are a bit overbuilt...
$160.001 in stock.View
Extralite's Cyberends are an even lighter version of the Ultraends, CNC-machined from a solid block of 7075 T6 aluminum using sophisticated 3D...
$135.002 options.View
Specifications Weight 105 grams Width 560 mm Bend 4 degrees Clamp Size 25.4 mm Details This is one of the lightest flat MTB bars we sell...
$135.001 in stock.View
Specifications Weight 135 grams Width 600 mm Bend 6 degrees + 6 degrees Clamp Size 25.4 mm Rise 15 mm Details This is one of the...
$145.001 in stock.View
Specifications Weight 135 grams Width 600 mm Back Sweep 8 degrees Stem Clamp Diameter 31.8 mm Detail This T7 Scandium-Aluminum flat...
$60.002 options.View
KCNC 'Outta My Face' MTB Bar-end Plugs Colorful, secure fitting CNC machined 6061 aluminum bar-end plugs for your mountain bike, available in Black,...
$25.004 options.View
Specifications Weight 51 grams Material 7075 aluminum Details KCNC's lightweight bar ends are designed with a contoured CNC machined shape with...
$70.005 options.View
Specifications Weight62 gramsBody Material6061 aluminumBolt Materialstainless steelClamp Diameter22.2 mm Detail KCNC's BE2 bar ends feature the same...
$36.001 options.View
Specifications Weight, 31.8 mm 237 grams Weight, 25.4 mm 224 grams Length 710 mm Stem Clamp Diameters 25.4 mm, 31.8 mm ...
$75.002 options.View
Scandium T - 7451 Dia: 25.4 or 31.8 Width: 600mm Rise: 0 Bend: 5° For XC use. Weight : 115g
$70.002 options.View
Specifications Weight 120 grams Length 600 mm Sweep 5 ° Stem Clamp Diameter 31.8 mm Detail New Ultimate's scandium-aluminum mountain...
$75.000 in stock.View
New Ultimate's new Flatbar will be one of the lightest in the world at only 99 grams on the scale. 580 mm wide and with over 200 mm to mount...
$140.002 options.View
Specifications Weight 120 grams Material UD carbon fiber Length 620 mm Stem Clamp Diameter 31.8 mm Rise 30 mm Sweep 8 degrees Detail New...
$155.002 options.View
Specifications Weight60 - 85 gramsAvailable Widths460 - 620 mmBack Sweep6 degreeStem Clamp24.5 mmFinish3k weave carbon Detail Schmolke Carbon was...
$330.005 options.View
Specifications Weight60 - 88 gramsAvailable Widths480 - 680 mmBack Sweep6 degreeStem Clamp31.8 mm Detail Schmolke Carbon was founded in 1993, shortly...
$350.006 options.View
Specifications Weight95 - 110 gramsAvailable Widths600 mm - 800 mmRise15 mmBack Sweep6 degreeStem Clamp31.8 mmFinish3k weave carbon Detail Schmolke...
$375.006 options.View
Machined 7075T6 alloy bar ends. Black with Soul logo laser etched. 48grams per pair 26mm diameter. 116mm length.
$90.000 in stock.View
Specifications Weight 55 grams/pair Mounting Angle 9 degrees Grip Diameter 27 mm Body Material 7075 aluminum Fastener Material 6/4...
$105.0010 options.View
