Handlebar Tape & Grips
ESI Grips, Chunky
Specifications Weight75 grams per pair Length132 mm Outer Diameter32 mm Detail The popularity of our best-selling ESI grips is based on several...
$18.00
7 options.View
ESI Grips, Racer's Edge
Specifications Weight50 grams per pair Length132 mm Outer Diameter28 mm Detail The popularity of our best-selling ESI grips is based on several...
$18.00
7 options.View
Extralite UltraGrips
Extralite's UltraGrips are flat bar grips for the weight conscious rider. At only 16g for the pair, they are a significant weight savings over...
$25.00
6 in stock.View
GC Adarga Leather Tape
Specifications Material: Leather ColorsWhite, Black, Brown, Fuchsia, and Silver. Detail GC makes possibly the finest leather handlebar tape...
$70.00
6 options.View
GC Suede Handle Bar Tape
Specifications MaterialSuede ColorsBlack, Brown, Red, Blue, Purple, Teal, Gray Detail Soft touch Suede bar tape from GC. Soft, comfortable,...
$40.00
8 options.View
KCNC EVA Foam Grips
Specifications Weight per Pair 15 grams Detail KCNC's EVA foam grips provide a semi-ergonomic, lightweight perch for your hands. They are sold in...
$10.00
5 options.View
Lizard Skins DSP Bar Tape
Specifications Weight56 grams/set Thickness2.5 mm Roll Length208 cm (82") Detail In their DSP handlebar tape, Lizard Skins has found a perfect...
$30.00
8 options.View
Lizard Skins DSP Race Bar Tape
Specifications Weight50 grams/set Thickness1.8 mm Roll Length208 cm (82") Detail DSP Race bar tape is the latest evolution of Lizard Skins'...
$30.00
4 options.View
PRO Digital Carbon Bar Tape
Specifications Weight 42 grams per roll Details Premium grade Digital carbon bar tape with sticky silicon backing. Extremely durable with easy to...
$18.00
2 options.View
Veloflyte Carbon Bar Plugs
Specifications Weight 4.4 Grams/pair Material Carbon Fiber Details Veloflyte's 100% carbon fiber bar end plugs for road bikes are manufactured...
$35.00
0 in stock.View
