Handlebar Tape & Grips
Specifications Weight75 grams per pair Length132 mm Outer Diameter32 mm Detail The popularity of our best-selling ESI grips is based on several...
$18.007 options.View
Specifications Weight50 grams per pair Length132 mm Outer Diameter28 mm Detail The popularity of our best-selling ESI grips is based on several...
Extralite's UltraGrips are flat bar grips for the weight conscious rider. At only 16g for the pair, they are a significant weight savings over...
$25.005 in stock.View
Specifications Material: Leather ColorsWhite, Black, Brown, Fuchsia, and Silver. Detail GC makes possibly the finest leather handlebar tape...
$70.006 options.View
Specifications MaterialSuede ColorsBlack, Brown, Red, Blue, Purple, Teal, Gray Detail Soft touch Suede bar tape from GC. Soft, comfortable,...
$40.008 options.View
Specifications Weight per Pair 15 grams Detail KCNC's EVA foam grips provide a semi-ergonomic, lightweight perch for your hands. They are sold in...
$10.005 options.View
Specifications Weight56 grams/set Thickness2.5 mm Roll Length208 cm (82") Detail In their DSP handlebar tape, Lizard Skins has found a perfect...
$30.008 options.View
Specifications Weight50 grams/set Thickness1.8 mm Roll Length208 cm (82") Detail DSP Race bar tape is the latest evolution of Lizard Skins'...
$30.004 options.View
Specifications Weight 42 grams per roll Details Premium grade Digital carbon bar tape with sticky silicon backing. Extremely durable with easy to...
$18.002 options.View
Specifications Weight 4.4 Grams/pair Material Carbon Fiber Details Veloflyte's 100% carbon fiber bar end plugs for road bikes are manufactured...
$35.000 in stock.View
