Gore RideOn Professional Cable System
Gore RideOn Professional Cable System Derailleur - Black$65.00 Notify Me When Available
Gore RideOn Professional Cable System Derailleur - White$65.00 Notify Me When Available
Housing Diameter 4 mm
Housing Length 2050 mm
Front Cable Length 1900 mm
Rear Cable Length 2200 mm
Designed specifically for road bikes, Gore's Professional cable system sets the new standard for shifting performance in a diverse set of conditions. At the heart of this kit is Gore's patented, super slick coated cables which are paired with lubricated housing for superior low-friction performance. The Professional System design incorporates cable liners, sealed ferrules, and Gore-trademarked GRUB seals to enclose all exposed cables and ensure that contamination stays out of the system. While the immediate benefits of this system are readily apparent in smoother, easier shifting action, there are long term perks as well. Because shifts take less effort, your shifters' delicate internals will experience less wear. Your shifting performance will be less affected by inclement weather, and there will be less shifting accuracy degradation over time. If you ride consistently in inclement conditions this cable system is highly recommended.
Gore's Professional Derailleur System is compatible with Campagnolo, Sram, and Shimano shift systems. The included cables are double ended, with a Shimano/Sram head on one end and a Campagnolo head on the other.
The following is included in each Gore Professional System derailleur kit:
2.05 meters shift housing
1x front shift cable
1x rear shift cable
2x 1.2 mm cable sheaths with ferrules
3x standard ferrules
1x long nosed ferrule
2x GRUB seals
2x cable ends with rubber RideOn caps.
Visit Gore's website here for a list of recommended tools and detailed installation instructions.
Comment on Gore RideOn Professional Cable System
